Exhaust Gasket Removal, Please Help |
solex |
Apr 21 2006, 07:57 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
This backdate project is much more difficult then I thought it would be. The car is fighting every step of the way. My latest and hopefully last problem is trying to remove two exhaust gaskets.
A PO installed two on one port and I cannot seem to remove them. I tried: heat drill punch plier Nothing they will not budge. Any suggestions would be appreciated. Thanks, Dan |
zeekman914 |
Apr 21 2006, 08:00 PM
Member Group: Members Posts: 67 Joined: 1-December 04 From: Arcata, CA Member No.: 3,202 |
did you try to scrape them off? with like a screwdriver?
solex |
Apr 21 2006, 08:03 PM
The heads are in the car, I can't really get a screw driver into the port at an angle that would allow me to scrape them off.
I have been using a punch to try to deform them but no go. |
gklinger |
Apr 21 2006, 08:10 PM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
The heads are in the car, I can't really get a screw driver into the port at an angle that would allow me to scrape them off. I have been using a punch to try to deform them but no go. Try tapping them with a small chisel. They tend to sorta fold at the chisel line so you can get a cotter pin puller or similiar under it to pull it out. Be gentle so you don't damage the head. YMMV, but it worked for me. |
Allan |
Apr 21 2006, 08:28 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
They are like copper o-rings. Did you try to dig them out with a dental pick?
Worked for me. |
solex |
Apr 21 2006, 08:46 PM
Tried your suggestions and still they wont come out. The first ring is so deformed now that I created a ledge in which I can get some leverage with a big screw driver, but it will still not come out. It is as though the carbon from the exhaust has welded the two gaskets together and they are interferenced into the exhaust port.
Not sure what else to do? |
r_towle |
Apr 21 2006, 08:54 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
They are copper rings, set on aluminum heads.
They would never weld on. There may be a corrosive thing going on...but I doubt it aluminum>copper is not a big corrosion issue So, I would get a sharp wood chisel, and cut through one of them..then twist the legs towards the inside, and collapse it onto itself..it may loosen up the other one. Or dremel. Rich |
solex |
Apr 21 2006, 08:58 PM
Will do tomorrow, thanks guys.
SGB |
Apr 21 2006, 09:00 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I assume you have been blasting in copious amounts of some kinda penetrant? Also, maybe something that would attack the copper like , I dunno, .... Lime-A-Way or even draino. I'd wanna think about what it might do to the aluminum too....
Allan |
Apr 21 2006, 09:10 PM
Never had that kind of problem getting them out.
Are you sure you had a dental pick? If not, soak it in something and come back tomorrow. |
solex |
Apr 21 2006, 09:16 PM
A PO use a 10MM stud with a 15MM nut and must have over torqued it (I had to cut the nut to get it off) probally compressing the rings so that the are now wedged into the port. I soaked the rings in LR will let it set over night and try to cut them tomorrow.
Thank you all, will let you know how it progresses. |
solex |
May 19 2006, 02:13 PM
Finally got the gaskets out a few weeks ago. They were wedged in pretty well, I had to file down the new gasket so I would not have the problem again. I suspect the PO had a similar problem and instead of trying to get the one out they just inserted a new gasket over the old.
I actually made tool to give me more leverage in pulling the gasket out. Attached image(s) |
Lo-Fi Version | Time is now: 31st May 2024 - 10:22 PM |
