911 to 914 gauge transplant, (self explanitory) |
Aaron Cox |
Feb 23 2003, 07:54 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
I want to put an early 911 combo gauge in my teener to give me a heads up on oil pressure. To do this i would need a 911 fuel / oil level combo, and the gauge insert and sender for the 911 oil pressure. Then instead of oil level, i woul have an oil pressure indicator correctly labeled "oil" (best ya could do). Is it possible to use a 911 oil pressure sender on a 914/4 block? (IMG:style_emoticons/default/huh.gif) also, can i use my vdo dual sender, (operates dash light and another vdo cockpit gauge-used for engine break in process) Is all this possible?
bernbomb914 |
Feb 23 2003, 08:40 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
You need to get the sender that goes with that guage. they are all differant so you need to match them
Bernie (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:56 PM |
