Moving to phinox arizona, What do i need to do to the 914 so it will run well in the heat |
jporsche914 |
May 20 2006, 01:47 PM
Member Group: Members Posts: 149 Joined: 9-March 04 From: colorado, springs Member No.: 1,769 |
I am moving to arizona to go to UTI and i need to make the porsche reliable in the heat. I have already bought a fuel pump relocation kit and now i am looking to buy an oil cooler i just do not know were to begin. I found a couple of kit online one by autoatlanta but it seems to small and one by empi that seens alright. I just had some questions about where to mount the cooler and if i should just replace the stock cooler with a big bastard or just to put an auxilary cooler on the car and if there are any other things i need to do to it so it will run good down there? Thanks,
James |
So.Cal.914 |
May 20 2006, 01:56 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I lived in the low desert of Calif for eleven years. 125 is not uncommon duering
the summer.I put an external cooler and this helped. I also run the engine a little fat, this also seems to help. Other than that I try to keep my foot out of it and it has survived so far. (IMG:style_emoticons/default/smoke.gif) |
gregrobbins |
May 20 2006, 01:59 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
I have had two 914 with external oil coolers mounted on the engine compartment lid. Adds to the oil volume and seems to do a good job of cooling. Draw back is you no longer have the rain tray.
Oh wait, that isn't an issue as we never get rain in Phoenix. |
jporsche914 |
May 20 2006, 03:05 PM
What is the best was to run the oil to the oil cooler what kind of adapter?
gregrobbins |
May 20 2006, 03:46 PM
Pelican sells an adapter that mounts where the oil filter is located and you run you cooler lines from there. PM or email me when you get to town and I can show you my set up.
Attached image(s) |
rhodyguy |
May 20 2006, 04:43 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i would think a GT style engine lid would help too.
k |
ThinAir |
May 20 2006, 10:15 PM
Best friends Group: Members Posts: 2,542 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
... external oil coolers mounted on the engine compartment lid. Adds to the oil volume and seems to do a good job of cooling... Sorry Greg, but I don't think this is good advice. Yes it adds oil capacity, but mounted in that location it preheats the intake air. This can negate any cooling benefit you are getting by running the oil cooler. I burned up a VW Bus this way. Assuming that an external oil cooler is even needed, it should not be mounted where it can heat the intake air. I've seen some pictures here of someone who mounted one on the underside of his rear trunk with a fan to ensure air flow. I think you'll get far more benefit from making sure that your cylinder fins are all clean and allowing good air flow and from making sure your engine is correctly timed and the valves adjusted than you will get from running an external oil cooler. Relocating the fuel pump to the front is a very good idea. Change to steel fuel lines while you are at it (although the fuel lines have nothing to do with living in a hot place). I made this change myself after a vapor lock problem when I took it down to Phoenix. |
anthony |
May 20 2006, 10:21 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Say, worst case scenario it's 120F. Does an extra 40deg F of ambient temperature make that much of a difference to an engine that sees over 200F?
I've run my 914 all day in 90F weather with no issues. The only thing that sucks is that it doesn't have a good A/C system. I think I'd be more worried about the desert sun eating up the rubber and paint. I hope this isn't your only vehicle. I've been in Phoenix in the summer and you'll be suffering without a newer car and a good A/C system. |
BMartin914 |
May 20 2006, 11:20 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 23rd May 2024 - 02:58 PM |
