| Thack |
Jun 3 2006, 04:30 PM
Member ![]() ![]() Group: Members Posts: 283 Joined: 1-June 05 From: Houston, Tx Member No.: 4,182 |
Before I ruin something any tips for getting that cylinder out. I have my wheel off and the turn sig. switch assy. I can pull the cylinder out so far but I can't depress that spring keeper on the cylinder. If I can depress it will it come straight out? Thanks.
| Aaron Cox |
Jun 3 2006, 04:31 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
dont you need the key in, and turned as to pull in the "lock"
i believe a tech article is on pelican about this |
| Thack |
Jun 3 2006, 04:44 PM
You should be able to pull these out without the key. I'm looking at Pelican's but my '76 doesn't look like the article.
| Thack |
Jun 3 2006, 09:17 PM
I got the cylinder out. There are two different cylinders. I'm going to re-key the existing cylinder.
| Thack |
Jun 4 2006, 08:34 PM
Couldn't re-key it so I modified the 70-71 cylinder I bought for $5.
This is what I am installing after maching the switch engagement drive. Notice how I had to drill a hole to get the old cylinder out, no fun. Also the tumbler I could re-key is shown. Attached image(s)
Lo-Fi Version | Time is now: 2nd April 2026 - 10:07 PM |
