Type 4 Unleashed |
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None ![]() |
8740 Chrom Moly cut to fit cyl studs
190,000 psi .900" longer than stock I'am installing a set tomorrow in a case, to check fitment. There are also, 8740 10mm case thru studs, which the very first set are currently installed in my motor. (IMG:http://i71.photobucket.com/albums/i134/Type4Unleashed/2006_0609Image0024.jpg) (IMG:http://i71.photobucket.com/albums/i134/Type4Unleashed/2006_0418Image0003.jpg) |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
very nice!
Type 4 Unleashed |
The Pictures suck, I'll get better ones tomorrow.
Type 4 Unleashed |
I, test fitted a set to my case today, it required the threads be cleaned up, (tappped clean).
I, installed a 105mm cyl with over .800" of cyl spacers, and the studs still required to be cut. I, forgot my camera (IMG:style_emoticons/default/bootyshake.gif) I, swaped out a pic of the studs, a little better, but these things just don't like to be shot. I'am running them in my new motor, along with the 10mm case thru bolts, that I'am already using in my current motor. |
Lo-Fi Version | Time is now: 17th June 2024 - 09:30 AM |
