adjusting rear ride height?, what are my options? |
dion9146 |
Jul 2 2006, 02:31 PM
Member Group: Members Posts: 469 Joined: 16-May 04 From: Buckner, KY Member No.: 2,071 Region Association: MidAtlantic Region |
OK, time for a stupid question. I've owned 3 914s, and I have been able to achieve the perfect ride height on the first two. Of course, I had Koni adjustables with the adjustable spring perches, so setting the ride height was easy.
On this car (1974 - 2.0 6 cylinder), I have Koni reds with non-adjustable spring perches and Weltmeister 200 lb springs. I'd like to lower the rear another inch. What are my options? I'm guessing I need to get another set of rear springs/struts, but I thought I'd check here first. Gracias, Dion |
Aaron Cox |
Jul 2 2006, 06:35 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
threaded collars and 2.5" ID springs (racecar springs)
about 200 from ground control, or you can piece it together from colemanracing.com as i did. see my blog. link in my signature. |
Lo-Fi Version | Time is now: 6th June 2024 - 02:05 PM |
