Grease me up! |
Grease me up! |
swood |
Jul 15 2006, 09:52 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
What grease should be used on the following:
Poly Bronze bushings Wheel bearings front and back (they get packed right?) Torsion bars I'm sure I'm doing other things that need some lubrication...can't think at the moment. I have a tube of Swepco Moly. Good for anything? Thanks. (IMG:style_emoticons/default/chowtime.gif) |
Qarl |
Jul 15 2006, 09:56 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I used Mobil 1 synthetic for the front and rear bearings... Swepco moly should be okay
Not sure about the Poly Bronze... aren't they self-lubricating? |
swood |
Jul 16 2006, 09:29 AM
No, I don't think the PB's are self lubing. They have the zircs for lubing.
Allan |
Jul 16 2006, 09:42 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
SLITS |
Jul 16 2006, 10:28 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I used Mobil 1 synthetic for the front and rear bearings... How did you lube the rears? I didn't use anything on mine when I installed them. They're talking about suspension bearings (bushings). The rear wheel bearing are sealed....no lubrication. Front wheel bearing...standard wheel bearing grease is all that is needed. |
Brad Roberts |
Jul 16 2006, 11:23 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Swepco will work fine.
B |
Qarl |
Jul 16 2006, 11:26 AM
Yeah... I was thinking of what I did for the roller bearings in the rear.
If you use the Weltmeister polygraphite bushings, then you use whale snot. Swepco, synthetic, marine grease, generic wheel grease... they all work fine for the front. |
Brad Roberts |
Jul 16 2006, 11:32 AM
My personal preference is the boat trailer wheel bearing grease for ANY suspension related item.
It is designed for "water" Duh! It is designed for hot/cold shock (trailer from freeway into lake) Every autoparts store carry's it. B |
Lo-Fi Version | Time is now: 7th June 2024 - 03:49 AM |
