| Mark Henry |
Feb 27 2003, 02:21 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Programmable electronic fuel injection (PEFI)
Is anyone interested in a SDS PEFI GROUP BUY? Base system list is $785 or $1165 for the full meal deal (crank trigger ignition) for the 4-cylinder version.(full list price, not counting discount) Discount is 10% off for 2 systems and up to 25% off for 10 systems. So that could = the base 4 cylinder system for approximately $600* or about the price of a new MPS. *(Based on the basic system, no options with 10 people in the buy for a 25% discount, no shipping.) This is for the brain only, many options, you must check out their site and decide what you want/need. Will work on the stock engine and intake system to get you going. Then you can go hipo crazy (cam, TB’s, stroker, etc.) if you want. (I think with a few options $800. to $1000.+ is maybe a more realistic cost per system.) http://www.sdsefi.com/ The points I like about it are: you don’t need a laptop (which is good for me as I’m totally ‘puter stupid), the controller stays in the car, they will build it with a real CHT sender, they custom tailor the harness, the base system isn’t too expensive, info BBS, they have aircooled experience and the guy uses it on his own plane. A couple of bugs and a couple of 911’s are running this system, one 914 in progress. Check it out, sounds good to me, but if you’ve heard anything bad about them let me know. The only real negatives that I have heard so far is; the CPU isn’t waterproof and the 914 guy said that he was having trouble (stock fan) mounting the crank trigger. 6 cylinder version base price $ 815, full meal deal $1320. (full list price, not counting discount) 8 cylinder and Mazda 2 rotor systems also available. If anyone is interested shoot me an email. I’m thinking about buying at the end of April/May. mhenry69@sympatico.ca |
| 914Timo |
Feb 28 2003, 01:43 AM
******* ![]() ![]() ![]() Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
Good idea and very nice system, but I like more finnish HesTec. The price should be about the same. (IMG:style_emoticons/default/blink.gif)
| Mark Henry |
Feb 28 2003, 05:23 PM
Timo, that system still requires a laptop computer so in my view it’s way more expensive.
The SDS does not require a PC, the controller stays in the car (you can remove it if you like) and one person can program it as they drive. No need for rolling dyno time. You do not have to play with a computer program if you just change your timing a couple of degrees. One racecar driver states that he did a bunch of changes to the engine just before the start of a race, he reported that he dialed in the PEFI by the 1st corner. The SDS system may not be for everyone, ‘puter geeks may be lost without the PC and the reams of useless (to me) information they can produce. (IMG:style_emoticons/default/wink.gif) To me the fact that the system is Canadian is kind of cool, but very low on my decision making list. It would be a tad cheaper to ship to people in the United States from Canada than Finland. As long as everyone in the group buy pays individually, they will ship directly to each single person. The only thing I get out of this is the same discount everyone else gets. |
| Mueller |
Feb 28 2003, 05:36 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
I looked at the SDS system, but me being me (cheap and I tend to break things) I couldn't justify the cost....(and then the repair)
Mark, It seems to me that you have a computer......can you get it close enough to the garage to run a 10ft or so cable? If so, then no need to have a laptop...yep it's that darn Megasquirt again....almost as annoying as this guy (IMG:style_emoticons/default/mueba.gif) (IMG:style_emoticons/default/mueba.gif) FYI, the Megasquirt is coming out with a DIY package that will allow one to modify the ECU while driving or pretty much wherever without the need for a Laptop or a PC. To me, it looks like a version similar to the pendant that the SDS uses. Post your find on shoptalkforums as well as a few of the 911 boards...get the word out on the group buy so that you can take advantage of it....good luck and keep us informed |
| Mark Henry |
Feb 28 2003, 05:42 PM
When is Mega squirt going to be available next?
I totally clueless with electronics, can I do it? how long is build time? |
| Mueller |
Feb 28 2003, 05:55 PM
Not sure when the next group buy is....soon I would think....
Can you build one??? Can you zip-up your pants without getting the beans or the frank caught??? (IMG:style_emoticons/default/blink.gif) If so, you might have the skill to build one (IMG:style_emoticons/default/smile.gif) Whether or not it works is another story........ Truthfully, the MS (Megasquirt) is not for everyone...hell, somedays it's not even for me and I thrive on this DIY cr@p just for bragging rights around here at the office... Soldering is easy once you get the hang of it...it's the electrical troubleshooting that can be a problem if something is hooked up wrong.....but this can happen with any aftermarket or factory FI system.....paying attention to details and knowing what does what and why and how one input can change the parameters is very important. Basicly a bunch of reading and studying and hopefully not making too many mistakes....the mistakes are sorta fun,I enjoy the trouble shooting and it "forces" you to learn how it works. |
| JeffBowlsby |
Feb 28 2003, 06:44 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
I think the SDS system is a great candidate for someone to buy, calibrate to the 914 and sell as a turnkey system.
The control box could be inserted into the OEM ECU box and the harness could be easy enough to make/retrofit for the 914. If I wanted to tinker...maybe the MS woudl be the ticket. Buts SDS has a long history of applications, is competitively priced and would be my aftermarket FI system of choice...I think. Hows that for decisiveness. |
| airsix |
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Don't rule out systems that need a laptop! I program my MIC3 with a 486 laptop I bought for $30.
-Ben M. |
| Mark Henry |
Feb 28 2003, 10:59 PM
Bowlsby gave this system a thumbs up, (I think (IMG:style_emoticons/default/wink.gif) )
so I do think I'm on the right track,even if no one else steps up to the plate. Mueller, the Mega Squirt is interesting but I don't have a lot of patience, I would rather pay, plug and play. I'm a bit of a bargoon hunter myself, but I have such horseshoes flying out of my butt when it comes to my cars, that I rarely cheap out on parts. You can call it a karma thing. Jeff, the "stick it into an old OEM ECU box" idea is pure genus. I might just do that. Ben I'll check out the MIC3 (do you have the link) but I don't see how I can drive and punch away at a PC easy. I change shit all the time so I will be reprogramming a lot. |
| JeffBowlsby |
Mar 1 2003, 12:27 AM
Yesm, that was my official thumbs up on the SDS.
The MS system has its positives too, but for many 914 owners like you and me...we just want to plug and play. Mike Cooley from Tacoma put in an Autronic a couple years ago and had to do alot of the R&D to get it to work, I would not want to go to that effort. something like18 months downtime. Life is too short for that. SDS seems to have it as hassle-free as is possible with any generic aftermarket system. In concept, I don't have a problem with programming via laptop, but the reality is, the car with the aftermarket FI may need tweaking from time to time. I prefer the idea of a single-source manufacturer-provided programmer that does not rely on a laptop working 10-15-20 years from now. If it somehow breaks...SDS will likely be around in 2020 to fix/replace it. Besides, I can make one of my cool FI harnesses to dress it all up. The main thing I don't like is that uglee gold box...it just does not look stock. But I wouldnt expect any mfr to do that... |
| jonwatts |
Mar 1 2003, 12:34 AM
no rules, just wrong ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
I'm not knocking this system because I haven't used it. In fact, I haven't used any EFI system that has a programming pendant, but I have used other pendant systems and I'm not totally convinced they make a task easier; (usually just monotonous).
It's analogous to the address book in a cell phone. Do you want to enter my name by pressing the number '4' three times followed by the '#' key to make an uppercase 'J' or would you rather enter my info with a regular computer keyboard and then download it to the phone? Yes, the computer download method will probably not work the first time (or the first 10 times) and will require some debugging, but if you have 200 names in your address book it's still the easiest way to do it. Plus you have all that data somewhere that can be backed up (like onto a CDROM). Look, I'm an embedded software engineer by trade so I like things to be as simple and straightforward as possible. You might think I'd prefer the pendant but in the case of EFI there is a lot of data to be input and retrieved (more than you can effectively show with a 2x16 LCD display). I think a computer allows the flexibility to display everything in a table or graph and let you see the trends of what is going on with the data. (I'm glad those Windows programming b@stards at work aren't reading this). All that said, don't let me talk you out of it. Anybody doing something like this needs to be encouraged. I hope you get some takers on the group buy. I'm finding that figuring out all the stuff for my installation is a huge amount of fun. |
| airsix |
Mar 1 2003, 12:53 AM
QUOTE(Mark Henry @ Feb 28 2003, 08:59 PM) Ben I'll check out the MIC3 (do you have the link) but I don't see how I can drive and punch away at a PC easy. I change shit all the time so I will be reprogramming a lot. I just meant don't avoid a good system just because it needs a laptop, because you can get a laptop that will do the job for cheap. You actually can't get the MIC3 any more. It has evolved into the PRS series. More features. More $. http://www.perfectpower.com The SDS has a good reputation and seems to be a great bang for the buck. Best bang for the buck? Megasquirt. No contest. At your ~$800 target you're also in the range of the Autronic SMC at discount prices. The Autronic is a nice unit. I'd definitely consider it. -Ben |
| Mark Henry |
Mar 2 2003, 07:23 AM
Jon, I think you should read the SDS info again. One testimonial has a racer saying he reprogrammed his FI by the first corner while driving under race conditions. Of course this may be a biased testimonial, but it doesn’t get much faster then the first corner. I've done maps, on a friend’s Haltech and quite frankly I'd rather have root canal. (IMG:style_emoticons/default/blink.gif)
Ben, Autronic? Bowlsby’s last post says he knows a guy that took a manure wagonload of R&D and 18 months for that system to work. For that kind of time I’ll do the Mega Squirt. I want plug and play in 1 or 2 weekends at the most. Hell, if it going to take that kind of time I’ll just buy a set of 44 IDF Weber’s. Reality is I want a higher tech system than just carb’s and if I get talked out of SDS, I will go with the Haltech, its only a 100 bucks more. The major thing I don’t like about the Haltech is it’s made for a water-cooled, with a generic wiring harness that you have to cut and splice to fit an aircooled. Simple is what I'm after, as I’m not much of a 'puter guy. When I got my new 'puter I took my old tower outside and shot it with my 12 gauge. It may be just an inanimate object, but it sure made me happy! (IMG:style_emoticons/default/fighting19.gif) |
| seanery |
Mar 2 2003, 09:39 AM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
What about Electromotive Tek 3 ?
I know its pricey, but isn't it THE shit to have? |
| Mueller |
Mar 2 2003, 11:23 AM
QUOTE Mark wrote: major thing I don’t like about the Haltech is it’s made for a water-cooled, with a generic wiring harness that you have to cut and splice to fit an aircooled. Believe me, the SDS or anything else out there is not going to easily bolt or plug-n-play. The problems Mike Cooley had I believe had nothing to do with him or the Autronic unit...he was using a mechanic that IMHO, did know what the heck he was doing.....most of the PEFI units are very simple..... as with any engine, a known amount of gas and air will ignite to push the piston down...all the ECU does is try to keep this value balanced depending on the inputs of the sensors... The TPS (throttle postion sensor) 3 wires (ground) (+5v...from ECU) (signal, goes to the ECU, this will be less than 5v and varies with the movment of the butterfly, lower voltage at idle and higher voltage at WOT) Air temp sensor, 2 wires (1 ground, other goes back to ECU) Water temp or CHT....2 wires (1 wire with CHT since the engine is gounded) All this sensor does is tell the ECU to turn off the fuel enrichment...heck, if one lived in a warm place, this sensor would not even be needed. Currently with my MS, I am using the stock CHT, when the motor reaches operating temperature, the CHT reads 300ohms (I'm guessing here, I don't have my notes with me), guess what? The GM sensors used for Water temp read 180° when they reach 300ohms...this triggers the ECU to disable the fuel enrichment...this can changed to any value you want, 160° +/- 50° if you wish. fuel injectors, 2 wires each MAP (3 wires and a hose) same thing as the TPS except that it is looking for vacuum or pressure Once you go PEFI , you'll never want to go back to anything else...it is precise and sorta bitchin knowing how perfect it is and that it's almost alive while doing it's job of keeping the engine running The ECU is a well trained machine and once your parameters are set, all the ECU wants to do is keep you happy and it will give the correct signal to the fuel injectors based on the input it gets from the TPS, MAP, ATS, CHT and 02 (if it has one) Sorry for the ramble, i wish I could write my thoughts better so that they make more sense |
| airsix |
Mar 2 2003, 11:54 AM
Mueller is right. PEFI is great. I am very glad I did mine. BUT... None of the systems are a simple "plug and play". None of them.
Things you are going to have to deal with: 1) you are going to have to build a wiring harness. NOBODY provides a plug and play harness. 2) you are going to have to figure out a way to provide a crank possition signal. 3) you are going to have to build an ignition system 4) you are going to have to troubleshoot for hours to find the ONE little thing you did wrong. 5) you are going to have to tune the system and you ARE NOT going to be able to do it while going around a track by yourself. I'll finish off by summing it all up in two statements. 1) The reality is that it will be many times more difficult than you think. 2) The end result is worth it. -Ben ps - I would never trade my tuning screen for a one-line LCD controller. One of the primary benefits of the laptop tunable systesm is all the information you can see live on-screen. It makes it much easier to understand what is happening and why. (That's not a criticism of the SDS which i think is a great system. Just personal preference) |
| Alfred |
Mar 2 2003, 12:22 PM
Unregistered |
Does anyone have experience with the CB Performance system? They sell one specifically for the 914.
Alfred |
| Mark Henry |
Mar 2 2003, 12:39 PM
This is the links to the compatition, most won't even give you a price list:
http://www.emi.cc/ http://www.haltech.com.au/ http://www.motec.com/ http://www.tciauto.com/ecu/spe_menu.htm http://www.mrgasket.com/accel.htm http://www.bgsoflex.com/megasquirt.html This is the link to the SDS FAQ page: http://www.sdsefi.com/adv.htm Yes, some of the testamonials 'may' be biased, but they are pushing this system as the eaziest system to program. Mueller, I agree with most of what you said, but how hard is it going to be to install a system that has a custom, made to your spec, wiring harness? I mean it doesn't have many more wires than a stereo and I can do that in an afternoon taking my time. I know thats not the same, but it really only has one big wire to run to the dash, the rest should be not much more than the stock harness. I really don't think 1-2 weekends for the install is out of line. |
| Mark Henry |
Mar 2 2003, 12:51 PM
IMHO the CB system sucks, it isn't even in the running. I'll take a progressive carb first!
The CB system has no program to tweek and little adjustment. The plus side is it is a complete system with dual (but cheap) TB's for about $1800. US. FI only, no ignition. |
| Mueller |
Mar 2 2003, 01:05 PM
Why are people so hung up on the wiring harness?
Here is a link to the Megasquirt wiring diagram 16 wires...oh noooooo (IMG:style_emoticons/default/smile.gif) http://www.bgsoflex.com/sensorwire.pdf The sensors that show one wire going to the ECU are grounded, either directly on the engine or with a wire going to a common ground. I agree with you on the CB setup, the reason it is not all that great is that the ECU is not getting enough information from the engine....a few more sensors and it would be a kick ass system |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:08 AM |
