New Problem - Idle at 3000 RPM, ... how else can I adjust |
vesnyder |
Jul 24 2006, 02:52 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
Just got my car running after pulling the motor and the idle is up around 3k RPM! What can I do to adjust it down? Tried the screw on the throttle body and on the controller - what other adjustments should I attempt?
Rand |
Jul 24 2006, 02:55 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Must be a vacuum leak. Triple check every tap/hose below the butterfly in the throttle body, plenum.
Eric Taylor |
Jul 24 2006, 02:57 PM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
Vance - Adjusting the throttle body won't help in this case. That is just to control small variations in your idle. What it sounds like is that you have a very serious vaccum leak some where. Most likely one or more hoses have poped off and all that you need to do is find them and put them back on and the car should idle more around 1k. Kinda scary the first time this happens, but not really a big deal in the end (IMG:style_emoticons/default/smile.gif) .
ERic |
tdgray |
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Vance... I answered in your other thread.
Check and / or replace all your vacuum lines. You've got a leak. Most likely it is the AAR hose connection loop. At least that's what mine was. Go to it. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 07:20 AM |
