Rear shock upgrade...Does anyone know who offers, the parts to convert to a threaded body? |
wbergtho |
Sep 23 2006, 06:13 PM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
I have Bilstein rear shocks and would like to upgrade them to the infinitely adjustable threaded body style. I understand a few members have done this and I'm just trying to get some idea of who sells the kit...or who has made their own...and what parts were used? Thanks for any help on this subject. (IMG:style_emoticons/default/aktion035.gif)
Bill |
Allan |
Sep 23 2006, 06:41 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Colemanracing.com
Mueller |
Sep 23 2006, 06:53 PM
here you go...just make sure you get the right ID, they have 2 different sizes for the Koni's and other shocks...there are also different lengths of the threaded tube.
Coleman Racing coil-over kit..one of many (the one I am using on my boge shocks |
wbergtho |
Sep 24 2006, 08:50 AM
I checked out Coleman Racing & Ground Control. Looks like the threaded body slips right over the original shock body...correct? I'm curious how it is adhered? Do you slip it over and pin it or set screw it or weld it on? How did you do it?
914werke |
Sep 24 2006, 10:12 AM
"I got blisters on me fingers" Group: Members Posts: 10,120 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Your Bilstiens should have a circlip in one of the
4 or 5 notches in the shock body. The sleaves are close enough tolerance fit that they simply rest on that clip. |
wbergtho |
Sep 24 2006, 10:38 AM
QUOTE Your Bilstiens should have a circlip in one of the 4 or 5 notches in the shock body. The sleaves are close enough tolerance fit that they simply rest on that clip. That makes perfect sense. What set up do you have and what diameter springs are typical....2" and/or 2.5" |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:03 AM |
