Turn signal problem |
akellym |
Oct 10 2006, 09:54 PM
Eyes Of The Deep Battle Group: Members Posts: 597 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region |
My left turn signal is not working right. When the key is off, if you turn on the left signal my center counsel lights up. The key on and the signal moved to left and would blink very dim, with both indicators in the dash lighting up. Now nothing out of the left, unless in hazard then the left blinks dim. The right works fine.
So.Cal.914 |
Oct 10 2006, 11:23 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Sounds more like a power problem than a hardware problem. Try cleaning
your grounds the one above the fuse panel (under the dash) as well as the others. I was haveing all sorts of problems (electrical) and cleaned all the grounds, didn't help everything. Pulled the fuse panel and cleaned all the contacts, perfect. If you havn't done this sence you've owned it should be done anyway. |
akellym |
Oct 11 2006, 01:15 PM
Grounds are good.
ryap |
Oct 11 2006, 03:27 PM
Newbie Group: Members Posts: 7 Joined: 19-July 06 From: Los Angeles Member No.: 6,465 |
My turn signal indicator is on all the time. Any suggestions?
jsteele22 |
Oct 11 2006, 03:32 PM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
bd1308 |
Oct 11 2006, 05:47 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
I have the late model one turn signal indicator, and mine stays on too as well...grounds?
My flasher light glows when i pull the light switch, Ive heard that wasnt normal. |
akellym |
Oct 11 2006, 06:37 PM
Well it's fixed (IMG:style_emoticons/default/biggrin.gif) The contacts in the switch needed cleaning, that was easy. The hard part was getting it back together(3hrs later). Stupid srpings (IMG:style_emoticons/default/headbang.gif)
Lo-Fi Version | Time is now: 3rd June 2024 - 05:57 AM |
