Unique Electrical Phenomenon, Ignition and lights on - blinker activates fuel pump? |
root |
Oct 12 2006, 06:16 PM
Two Wheeled Type4 Completed! Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
Today I noticed the right parking light was on but dimmer than the left one.
I had the ignition on and parking lights on. Then when I tried the right blinker the right blinker light didn't flash but the fuel pump came for a second. Left blinker works O.K. Looks like the blinker assemble comes off this weekend. Anybody have any fodder in this area? (IMG:style_emoticons/default/headbang.gif) |
MecGen |
Oct 12 2006, 06:42 PM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hi
You realy need to check your Battery/Chasis grounds. Bad grounds give symptoms excactly like what you have. Make sure everthing is there, and tight. If you need to open your turn signal switch, I can't help.... (IMG:style_emoticons/default/blink.gif) never did it. Later (IMG:style_emoticons/default/beerchug.gif) |
So.Cal.914 |
Oct 12 2006, 08:18 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I think your teener did to many drugs in the 70's
First check what MecGen sudjested. Have you done any wireing or added anything to your car lately? Has there been the smell of burning wires or anything else you should tell us? |
bd1308 |
Oct 12 2006, 08:41 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
have a GOOOOOD look at your fuses, Ive had one that jumped track and was between two fingers, and did some really funky things.
It started playing Iron Butterfly and smoke came out from beneath the dash. |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:31 AM |
