Heater/Vent control tricks? |
Scott S |
Oct 13 2006, 11:36 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All
My front fresh air fan has never worked. I pulled it out when I had the gas tank out, and even with direct power, it's dead. So, I am goin to replace it this winter. When I pulled it last time, I had lots of trouble getting all of the push/pull cables hooked back up. Does anyone know the correct sequence for dissassembly/re assembly? I am going to go through the entire system, and I want it to operate correctly. Any help is GREATLY appreciated! Thanks - Scott S |
brant |
Oct 13 2006, 11:41 AM
914 Wizard Group: Members Posts: 11,635 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
this is a job that requires a large amount of beer.
you see its a frustrating job, so you can use the beer to aid in frustration tolerance. good luck brant |
Lo-Fi Version | Time is now: 6th June 2024 - 03:41 AM |
