trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 885 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
Any one have any tips for making sure a 914 is straight before attempting a Long repair? Something that could be done without motor and trans? Or can point me to a thread to read?
Thanks -Pete Sorry if this is an old topic, but I could not find much with the search function |
GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
Up at the top of the page is 914 Info (next to Events Calendar). Click on it and you will find the body gap specs.
Put the car on jack stands and check the gaps. Adjust as required. take pictures as you go (IMG:style_emoticons/default/smile.gif) |
trojanhorsepower |
Great thanks!
One more thing, which of these would be considered critical indicators? I am guessing the obvious “h”. Any others? -Pete PS: Why is there no info on “y”? |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(trojanhorsepower @ Nov 4 2003, 09:37 PM) One more thing, which of these would be considered critical indicators? I am guessing the obvious “h”. Any others? "f" is all you need to get a quick idea on how bad it is, providing you know for sure your windshield hoop is not bend. (and if it is, this will tell you also) Andy |
SirAndy |
QUOTE(SirAndy @ Nov 4 2003, 09:42 PM) QUOTE(trojanhorsepower @ Nov 4 2003, 09:37 PM) One more thing, which of these would be considered critical indicators? I am guessing the obvious “h”. Any others? "f" is all you need to get a quick idea on how bad it is, providing you know for sure your windshield hoop is not bend. (and if it is, this will tell you also) Andy hey, i like quoting myself (IMG:style_emoticons/default/smile.gif) addon: use f and y to determine if your windshield-hoop is bend. if not, look at g and see if it is off. f will tell you if the car is sagging along the longs (f getting bigger) Andy |
trojanhorsepower |
I must be over looking something, because I can't find any data for the "y" measurment. Anyone know this one?
Thanks -Pete |
SirAndy |
QUOTE(trojanhorsepower @ Nov 4 2003, 09:50 PM) I must be over looking something, because I can't find any data for the "y" measurment. Anyone know this one? shit, you're right. someone forgot y. plus, looking closer, it looks like y goes to the pass. side upper pilar. in this case it's useless anyways. ok, now, you need: f g h x where f will really tell you how much the car is sagging on either side. my f actually shrank 1/4" during weld-in of the roll-cage ... Andy |
trojanhorsepower |
OK that should keep me out of trouble for a while.
Thanks again -Pete |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Actually Andy.. your car didnt shrink. It stayed right where it was. We measured all the cars before and after. The only one that shrank was Julius on one side (the side we didnt put the brace in).
B |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
If all measures up, put some braces in the doorgaps.
This will help prevent in- or decresing the distance between the targa bar and the windshiel hoop. You can build a simple frame that will help the car from sagging as well (supports the car over a larger area than just jack stands) (IMG:http://www.rennware.com/914/pics/r_long06.jpg) Now you can hack with conficence (IMG:style_emoticons/default/biggrin.gif) cheers, Jeroen |
GWN7 |
Good idea Jeroen (IMG:style_emoticons/default/clap56.gif) (adding that to my things to build list)
trojanhorsepower |
Jeroen,
Does that frame/brace include something to prop up the back and front of the car? Or should that not really be a concern? Thanks -Pete |
Jeroen |
Hey Pete,
No, it does not support the front or rear of the car. Just the longs But if you put doorbraces in it, it'll do just fine cheers, Jeroen |
trojanhorsepower |
OK great!
Maybe I will be able to get to the steel yard today and get some of that square tubing. -Pete |
SirAndy |
QUOTE(Brad Roberts @ Nov 4 2003, 11:13 PM) Actually Andy.. your car didnt shrink. It stayed right where it was. We measured all the cars before and after. The only one that shrank was Julius on one side (the side we didnt put the brace in). actually brad... it did! spec is 25 1/8 and mine measures right under 25. top didn't fit anymore, the rubber spacers were sitting on top of the targa bar instead of in their grooves on the lock. the side-seals were too long (had to cut them) ... Andy |
Brad Roberts |
Now I wonder why the other cars didnt shrink.
B |
SirAndy |
QUOTE(Brad Roberts @ Nov 5 2003, 12:46 PM) Now I wonder why the other cars didnt shrink. because the longs are completely rusted out on mine? or, when it was hit, the metal was weakend? or, tony was holding on to the windshield-hoop while he was brachiating (sp?) around in the car? (IMG:style_emoticons/default/confused24.gif) Andy |
Brad Roberts |
I wonder if you grabbed another top.. LOL
B |
SirAndy |
QUOTE(Brad Roberts @ Nov 5 2003, 01:08 PM) I wonder if you grabbed another top.. LOL hmmm, now here's a thought ... (IMG:style_emoticons/default/idea.gif) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,200 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
QUOTE(trojanhorsepower @ Nov 4 2003, 09:50 PM) I must be over looking something, because I can't find any data for the "y" measurment. Anyone know this one? Aaah, crap! Sorry about that!!! Dimension "Y": 1976mm (77 25/32 in.) Measured between outer corner of roll bar and outer edge of lower hole for hinge. --DD |
Lo-Fi Version | Time is now: 12th July 2025 - 11:26 AM |
