> Where do I find these metric nuts?
Hammy
post Oct 24 2006, 04:54 PM
mr. Wonderful
I've lost my steering wheel nut and washer. Is there anywhere local where I can find something as a replacement (I think I read it's 27mm?)? Osh only carries up to M12 sized nuts, local bug shop says they don't have any. Also I think I remember that washer being a special "wavy" kind or something.
Same thing for the nut that holds the clutch pedal tight, lost that too. (IMG:style_emoticons/default/dry.gif) Any idea on size of that?
thanks....
Allan
post Oct 24 2006, 04:56 PM
Teenerless Weenie
How soon do you need it?
I'll take a look in my parts car and see if there's one rolling around.
Allan
post Oct 24 2006, 05:07 PM
Teenerless Weenie
Found the nut and the wavey washer.
What's your address?
SLITS
post Oct 24 2006, 05:57 PM
"This Utah shit is HARSH!"
Easy ..... the man's losing his nutz
PORobinSCHE
post Oct 24 2006, 07:27 PM
i am more worried about the fellow that found his nutz. hope he used a glove (IMG:style_emoticons/default/bootyshake.gif)
Dave_Darling
post Oct 24 2006, 08:08 PM
914 Idiot
If the "other" nut you've lost is the one on the transmission end of the clutch cable, it's a standard M7 nut. Takes an 11mm wrench, usually. Use two regular M7 nuts and tighten them against each other so they don't "self-adjust" while you're driving.
--DD
So.Cal.914
post Oct 24 2006, 08:16 PM
"...And it has a front trunk too."
There are plenty of metric nuts on this site.
- Lo-Fi Version Time is now: 11th July 2025 - 03:37 AM
