Good book for rebuilding 914 motor?, Im keeping the 74! |
Ratt |
Nov 30 2003, 04:15 PM
Member Group: Members Posts: 85 Joined: 10-September 03 From: Goose Creek, SC Member No.: 1,136 |
Well I had my 914 up for sale for a while. My brother finaly convinced me to keep it. If I get it running he will take care of the body work. So as of now the car has a 1.7liter type 4 Bus motor. The PO did a ring job, but after 300 miles the 2&4 cyl have 30psi of pressure, and the valves arenot opening. I think its the cam. I pulled the motor today, and am going to start tearing down the motor. I was wondering if you knew of any good books that discuss the rebuild of AC motors?
Also What is the differance between the type 4 bus motor and the 914 motor? Would I be better off finding a old 914 2L and rebuilding that? Thanks for any help Andy Rattley |
Dave Bell |
Nov 30 2003, 04:19 PM
Member Group: Members Posts: 234 Joined: 27-November 03 From: Santa Clarita, CA Member No.: 1,398 Region Association: None |
"How to Rebuild Your Volkswaken Air-Cooled Engine", Tom Wilson
914 Haynes Manual Jake Raby has a Video out in the Bug Me Video Series, Volume 8, Type 4 Engine rebuild - Dave |
Dave_Darling |
Nov 30 2003, 04:33 PM
The Bus motors tend to have very low compression, less-aggressive cams, and often (particularly the 1.8 and 2.0 ones) smaller valves than the 914 versions of the same size engine. The oil filler and dipstick setup is different, and bolts onto the bottom-front (914 orientation) of the motor. You can't fit the funnel for the filler and dipstick into a 914 body that way, so you need to convert to a 914-style filler (easy) and dipstick (not so easy). Have to drill the hole for the 914 dipstick and press in a tube. Easy if you do it right, very unhappy if you do it wrong....
--DD |
Ratt |
Nov 30 2003, 04:36 PM
I was told it was a bus motor. Is there a way to tell the differance? Because what you said, It sounds like it is a 914 motor.
Thanks Andy |
VegasRacer |
Nov 30 2003, 04:40 PM
ELVIRA Group: Benefactors Posts: 8,524 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
What are the letters and numbers on the block?
Ratt |
Nov 30 2003, 04:43 PM
The numbers are EA049384 And then there is also a W2 marked by where the Tranny bolts on.
Andy |
Dave_Darling |
Nov 30 2003, 04:46 PM
Is there a "funnel" bolted onto the front side of the case over on the left side at the bottom? If so then it's a Bus engine. If not, it ain't. Could be a 411 wagon (I think) or a 914 engine. Functionally identical.
--DD |
Eric Taylor |
Nov 30 2003, 04:47 PM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
Sounds like a 1.7 914 motor, or at least case to me.
Eric |
Ratt |
Nov 30 2003, 04:48 PM
No there is no Funnle. So are the internals of the motors the same?
SirAndy |
Nov 30 2003, 07:14 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Ratt @ Nov 30 2003, 02:48 PM) No there is no Funnle. So are the internals of the motors the same? nope, the bus ran a different cam and pistons and heads ... but, someone could have replaced those with the proper 914 parts. EA is however a stock 914 1.7L case and NOT a bus case ... Andy |
Dave_Darling |
Nov 30 2003, 10:08 PM
EA was also used in the 411. Same power, same torque, same compression, same displacement. One version (I think it was the wagon, but it could have been the sedan) used a 914-style oil filler and dipstick; the other used the Bus-style one.
The internals on the EA-code 411 engine should be the same as the EA-code 914 engine. --DD |
Brad Roberts |
Nov 30 2003, 10:19 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Dave,
Please write a book on this crap. If Wayne can "write" a book... I know you can collaborate as well as he can. Write a "How to rebuild your T4" book. The ones available currently.. are close to worthless and old school. B |
VegasRacer |
Dec 1 2003, 05:15 AM
EA 000001 - EA 057000 are the engine codes for a 1972 1.7 914.
Jake Raby |
Dec 1 2003, 10:05 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
There were no in depth books, and still are not any that are up to date. Thats why I did a video.
I have people approach me about writing a book all the time, but a video is so much better. Problem with a book is finding a publisher that will believe that it will sale, they think no one builds 914s anymore! |
Brad Roberts |
Dec 1 2003, 01:38 PM
Problem with the video: Most people dont have VCR's and TV's in the garage. Its also gets old fast forwarding..backing up... forward...back...back some more.. The book can be flipped from page to page faster than I can work the remote.
I have seen 2-3 new 914 related books released in the last 4 years. There should be NO reason why you cant get a book published. Somebody here knows the name of the publishing company.. I think the writer was Patrick Dempsey (probably related to Wayne) B |
Lo-Fi Version | Time is now: 10th June 2024 - 10:45 AM |
