djm914-6 |
Happiness is: Getting on the road ![]() ![]() ![]() Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None ![]() |
First, can a complete DIY novice do a valve adjustment on a six?
Do you need to drain the oil first? How do you turn the engine's crank for find TDC and other markings? Any pointers to speed this procedure up? |
smontanaro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest ![]() |
BMartin914 |
||| ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest ![]() |
Yes you have to drain the oil. All 10 or 11 quarts of it. You also need to remove both upper and lower valve covers. It would probably help your cause to have individual feelers that can get in the space around the rockers (it is tight). At ths point it is just a matter of finding TDC on #1 and going through the firing order checking the clearances. It is not too easy, but can be done. It'll be good practice.
Lo-Fi Version | Time is now: 16th June 2024 - 10:15 PM |
