OT: Motorcycle guys, need help w/formula., Formula for figuring out MPH. |
Air_Cooled_Nut |
Apr 10 2007, 01:46 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Found while searching the vast internet:
Speed = (RPM x rear tire circumference x front sprocket) / (primary gear ratio x selected gear ratio x rear sprocket x 1056) Is this correct? Where does the "1056" number come from (IMG:style_emoticons/default/confused24.gif) This is different from the automotive one I have: Speed = (RPM x rear tire circumference) / (R&P x selected gear x 336) |
Crazyhippy |
Apr 10 2007, 09:42 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
Appears to be correct, not sure where the 1056 comes in... conversion from inches of tire circumfrence to MPH perhaps?
Also note the tire circumfrence changes pretty drastically w/ a bit of lean so 6000rpm straight might be 120mph, but 6000rpm dragging knee might only be 90mph... BJH |
Brian_Boss |
Apr 10 2007, 11:46 PM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
Is this correct? Where does the "1056" number come from (IMG:style_emoticons/default/confused24.gif) Unit conversion 12 (inches per foot) * 5280 (ft per mile) / 60 (min per hour) = 1056 |
Crazyhippy |
Apr 11 2007, 12:54 AM
Is this correct? Where does the "1056" number come from (IMG:style_emoticons/default/confused24.gif) Unit conversion 12 (inches per foot) * 5280 (ft per mile) / 60 (min per hour) = 1056 Knew that # looked familiar... I'm just too lazy to have done the math... (IMG:style_emoticons/default/thumb3d.gif) BJH (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 02:19 AM |
