TonyAKAVW |
That's my ride. ![]() ![]() ![]() ![]() Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None ![]() |
Saturday I'm going to install a 1987 911 SC front end onto my 1970 914. I'm wondering which flexible brake line to use. The early 914s (up to 71 I think) had one kind of hose and the later ones have a different style. Can I just use the 1970 style hoses I have on there now (which are maybe a couple years old) or do I need a different hose?
The difference is in the hose end and how it mounts to the car and the strut. -Tony |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
you have to modify the tab with the hole that they sit in.... or at least i did. got to drill it out an 1/8" larger IIRC.
TonyAKAVW |
Which tab? On the strut or on the body of the car?
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Tony,
I used the 914 brake line on mine. Aarons right, you have to ream out the tab on the strut so the end will fit through. I also had to modify the retaining clip a little. |
TonyAKAVW |
Okay, sounds doable. Thanks.
-Tony |
Lo-Fi Version | Time is now: 10th June 2024 - 01:43 PM |
