Push rod tube painting, To late...I already painted half |
whitey |
Apr 22 2007, 11:31 PM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
Unfortunately I thought to ask this question a little late...I've painted 4 tubes already. They have a primer and finish coat...they look great. Sounds like I should have left them alone. QUESTION: Should I bead blast the paint off of leave them with the paint.
DBCooper |
Apr 23 2007, 07:01 AM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Just thinking and I don't think I can remember seeing them painted. Paint shouldn't hurt anything, as long as you didn't paint in the grooves where the o-rings go, which would almost certainly cause them to leak. You'll also lose some of the oil cooling from the tubes, but as long as it's a thin coat that shouldn't be much. And you may have some adherence problems. Depends on the paint, but I don't think most paints will adhere well to the zinc coating after a lot of heat cycles. And you can always replace them later if they start to look ugly. If you still care by then.
Lo-Fi Version | Time is now: 1st June 2024 - 02:21 PM |
