I'm surprised it shifts at all! |
smontanaro |
Apr 24 2007, 09:07 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
I have modest goals for my car this spring/summer. Mostly I want to drive it a bit more and get it shifting better. It's a tailshiftin' /6. Last summer (I move at a snail's pace at times) I bought a bunch of bushings from Pelican for the car. Tonight I propped the rear end of the car up on jackstands and had a look around.
First I pulled the rear grease cover thingie and looked at the tail end: Not too bad. Then I pulled off the covers at the firewall: Hey! Where's the bushing? Then I got to thinking, "Hmmm... Isn't there supposed to be another one somewhere in the middle? Wait a minute! There's not only not a bushing. The bracket that's supposed to hold it is missing too! (At least I think that's where it goes.) And of course, the bracket is special to the 914/6, so it's probably made of unobtainium. I can do the work necessary to install the firewall bushing and might as well replace the rear one since I have a new one. Any idea where to get the bracket? Like I said in the subject, I'm surprised it shifts at all. And I haven't even looked under the shift lever yet (got a part for there as well - 911-424-139-00). Thx, Skip |
Aaron Cox |
Apr 24 2007, 09:09 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
is that u joint stock on a six????
sixnotfour |
Apr 24 2007, 09:14 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE is that u joint stock on a six???? yup QUOTE Then I got to thinking, "Hmmm... Isn't there supposed to be another one somewhere in the middle? nope |
smontanaro |
Apr 24 2007, 09:15 PM
Yes, I believe so, at least according to my copy of the parts manual. The /4 and
the /6 apparently differ a fair amount in that region. Skip |
smontanaro |
Apr 24 2007, 09:25 PM
So 914-424-012-00 is at the end of the shift rod? Where does the third bushing go?
The parts manual says three are required for both /6 and /4. What attaches to that bare stud on the engine case? Thx, Skip |
McMark |
Apr 24 2007, 09:55 PM
Inside the center tunnel. Pull your shifter and you'll find the third one. (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 06:43 AM |
