Which one do I have, Rockers |
BarberDave |
Jul 14 2007, 02:22 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
I have a set of 2.0 heads I am going to send out to be rebuilt . I also have a set of 1.7 heads ,i remember hearing that the 1.7 rockes are better?? Right or wrong ! If there are diferences in the 1.7 rockers, how do i identify which ones I have . I plan to run swivel foot ends. Dave (IMG:style_emoticons/default/slap.gif) |
Dave_Darling |
Jul 14 2007, 02:35 PM
The only difference is that the hole where the adjusters go is smaller. I believe it's 8mm on the 1.7 ones, and 10mm on the 2.0 ones. Which means that the good swivel-foot adjusters (the real 911 ones!) will only fit in the 1.7 rockers.
--DD |
Al Meredith |
Jul 14 2007, 07:21 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
YOU are correct, sir. (Ed McMann to Jonny Carson) You will have to trim some off the rocker to install the Porsche swivel feet adjusters. Check Jake's site I think he tells you how much to trim off.
Lo-Fi Version | Time is now: 1st June 2024 - 02:12 AM |
