rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,011 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
First, I'm not here to bash anyone. I'm to blame for the end result of my engine rebuild mistakes.
Here's what I figured out over the last several weeks dealing with machine shops. First, If your machine shop doesn't work on your type of engine on a regular basis be sure you know all the specs of everything you have and know exactly what you need in the end. This goes for the type IV as well as a flat 6, Subby, or water cooled V8. I had a shop repair my heads. The 928 has a lug on the end of the heads cast on for measuring the thickness of the heads. The stock thickness 24mm. The minimum thickness for machining is 23.6 mm. When you cut the heads you need to move from the stock gasket at 1.1 mm to a 1.4 mm thick gasket. I failed to measure the heads before I brought them into the shop. Based on where they ended up I can only assume the heads were cut once before they went into the shop. They were repaired and cut the heads. I again failed to measure the heads before I installed them or ask the shop if they checked them. I assumed they were in spec. My fault. The engine ran about 200 miles maybe less. I had a ticking sound from the time it started. When it failed a valve snapped off at the retainer, dropped into the cylinder, broke again, then the piston drove it into the head. This broke the piston and block. I brought my heads into a second shop to get an estimate for repair. The shop called me and told me it would cost $ 900.00 plus parts. Now because I just had these heads done I had a wierd feeling about cutting them again. I asked the shop how thick the head boss is. He didn't know and or didn't really know how to check them. I managed to give him clear enough insturctions over the phone. He check them and called me back. He told me one head was at 23.5 mm on one end and 23.6 on the other. Then told me the head that had the broken valve was at 23.1 mm (remember the minimum is 23.6 with a 1.4 gasket) I used the stock 1.1 mm gasket... Originally I thought I may have damaged an oil ring during installation. Based on my findings the oil ring was probably fine. But ultimately I still killed my own engine. Anywho, These heads are gold. Larger valves, larger ports, smaller combution chambers. The US engine is rated by Porsche at 218 hp the euro "S" engine I have is rated at 300 hp. That's pretty good from a 4.7 L I ordered a set of used euro "S" replacement cores for $ 1000.00 I figured that would need a valve job. Turns out these heads were also cut to 23.1 mm. (IMG:style_emoticons/default/headbang.gif) I'm returning the replacement cores to very reputable vendor no questions asked. (IMG:style_emoticons/default/clap56.gif) I'm back to repairing my heads. I'll need to cut the notches in the pistons a little deeper and degree the cams but at least I know what happened so I don't repete this problem. |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
OUCH.... That sucks. Good luck with that one.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
That's a sad, but quite interesting story Rick. I'm glad you were able to find the root cause of the failure.
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,290 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
I agree, knowing the cause(s) of failure is the first big step in correcting that. Dave Hunt certainly knows this lesson now. We sure hope this build of yours will produce 'out of this world' results.
rick 918-S |
Like I said, I can't blame anyone but myself. Shit happens. Around here, if it's not a Chevy you better be ready to educate. That means knowing the engine well yourself first. I know better. This time around I'm a little more mindful of the details. Stay tuned..
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Upon hearing your story, I remember visiting Renegade Hybrids in Las Vegas. After a shop tour, I asked which conversion was the easiest, and the owner replies "the 928, it's already set up for a v8".
Somehow, a chevy v8 conversion sounds very easy and cheap on a 928. Yes, I know you end up with a bastard stepchild, but any shop could work on it! |
Project 6 |
large member ![]() ![]() Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None ![]() ![]() |
Hmmm, machinist can do wonders once they know what they need to do. Can you use two gaskets or weld a bead and then machine again?
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Like I said, I can't blame anyone but myself. Shit happens. Around here, if it's not a Chevy you better be ready to educate. That means knowing the engine well yourself first. I know better. This time around I'm a little more mindful of the details. Stay tuned.. I went through something VERY similar last year with a customers 356 engine. Machine shop does wonders with water cooled engines BUT I had to take the heads back 3 times and explain to him the last time how they are to be cut and measured. |
Lo-Fi Version | Time is now: 9th July 2025 - 01:07 PM |
