Tire Pressure for Street and AutoX, What are you running? |
Steve |
Jan 3 2004, 02:41 PM
914 Guru Group: Members Posts: 5,611 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I'm running 205-50-16's in the front with 28lbs of pressure.
In the rear I'm running 245-45-16's with 30lbs of pressure. The car corners very neutral with this setup. I tried 29 and 32 and the car started to oversteer at the last autox. So I switched back to 28 and 30. I'm just curious was everyone else is running. Thanks for your help!! Steve |
ArtechnikA |
Jan 3 2004, 03:25 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(Steve @ Jan 3 2004, 12:41 PM) I'm running 205-50-16's in the front with 28lbs of pressure. In the rear I'm running 245-45-16's with 30lbs of pressure. what is the tire's Max Cold Inflation Pressure printed on the sidewall ? i'd start there ... |
Lo-Fi Version | Time is now: 7th June 2024 - 01:22 AM |
