Stainless steel body repair, Slow the inevitable |
Wilhelm |
Dec 12 2007, 02:21 AM
Member Group: Members Posts: 408 Joined: 7-September 07 From: Hooterville, OR Member No.: 8,088 Region Association: None |
1. Do any of the replacement manufacturors for rust prone parts make hell hole kits, floors, longs, or battery boxes out of stainless?
2. Would this seem problematitic? Could the same stamping dyes be used? 3. Anyone forsee issues with welding stainless to our 914 tubs? 4. How would you change your welding practice? (IMG:style_emoticons/default/welder.gif) Wilhelm #1 85 grey 928 # 6 914s in various states of armegedon. |
jd74914 |
Dec 12 2007, 10:00 AM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Welding dissimilar metals is never a good idea. You typically get very bad welds. If you really want to do it you have to braze.
As long as the mild steel replacement pieces are properly painted you should be good for another 30 years. (IMG:style_emoticons/default/smile.gif) |
sean_v8_914 |
Dec 12 2007, 01:54 PM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
electrolysis = rust
swl |
Dec 12 2007, 05:28 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
yup to what jim and sean said. Even if you get good welds you will have rust trying to form at the joint because of electrolysis. Mild steel coated with POR-15 or similar will last at least another 30 years.
But to answer your first question - no I have never seen body panels being offered in stainless. Heat exchangers - yes. Bumpers - yes (just recently) but no body parts. There is a bit of a history behind the molds for stamping these parts but from what I gather there is really only one source for each. Restoration Design is the source for most. I think George at Automobile Atlanta owns some of the molds as well. Should add that there is also some reinforcing pieces that are made by other folks. You can find them in the vendors forum. |
IronHillRestorations |
Dec 12 2007, 05:33 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Stainless is much harder than mild steel, so I don't think any existing tooling would work to stamp stainless.
The other consideration is that 914's that get restored probably will not see the circumstances that have brought it to the current state of corrosion. |
scotty b |
Dec 12 2007, 06:11 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Stainless is much harder than mild steel, so I don't think any existing tooling would work to stamp stainless. The other consideration is that 914's that get restored probably will not see the circumstances that have brought it to the current state of corrosion. (IMG:style_emoticons/default/agree.gif) I see posts on a regular basis oth here and on another site I frequent of people looking for an anti rust miracle for the future. The simple fact is that it took 30+ years of use and neglect for your car to get to the state it is in now. That said most of the people restoring their car are doing a complete job and will take MUCH better care of the car than was previously. Another MAJOR factor is the advancements in the paint tech being utilized today. Modern paints are a FAR cry from what they were 30 years agop. Forget about the S.S. idea, forget about galvanized dipping your body ( yes I have seen that brought up) do it once, use QUALITY products and take care of the car !! (IMG:style_emoticons/default/driving.gif) It will outlast you if all this is done properly. |
Katmanken |
Dec 13 2007, 07:53 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Gotta be careful welding stainless....
Our materials guy in college used to tell this tale... Some alloys weld fine and then over years degrade. There was a fire extinguisher manufacturing company that sold stainless steel extinguishers. One day there was a fire, a guy grabbed one, popped the CO2 cannister to vent the powder and blew the end off the fire extinguisher into his foot. Seems our teacher had to analyze the failure and it was right around the weld. Experimentation showed the welds were fine right after welding, and over years degraded. Weld away! Ken |
Lo-Fi Version | Time is now: 9th June 2024 - 09:46 AM |
