Real time djet help needed!, High idle |
championgt1 |
Jan 26 2008, 01:43 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Items noted 1:Using Dave Darling's diagram the line coming off the throttle body to the cap side port of the vacuum advance unit is plugged with a screw and not connected to the vacuum advance unit shown in top of picture. Does this line need to be connected to the cap side port of the vacuum advance unit? 2: The line from the back of the vacuum advance line is omited because the car is a 74 and does not have a port on the throttle body. |
brp986s |
Jan 26 2008, 02:04 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
the cap-side port off the ditributor is vac retard. It needs to see full time vacuum (from plenum), otherwise timing will be advanced and cause high idle. Could you post darlings diagram?
championgt1 |
Jan 26 2008, 02:33 PM
kevin here. so the vacum can port pictured should have a line connected to the tb port shown in the second picture, yes? there are a number of odities on this system as it's currently configured. i'm at jack's house.
k Attached image(s) |
brp986s |
Jan 26 2008, 02:47 PM
the port pointing to the right off the distributor in the top pic needs to be connected to the port pointing to the left off the tb on the bottom pic. (which already a tube connected to it).
championgt1 |
Jan 26 2008, 03:08 PM
brief history...jack's car produced an extremely high idle. prior to today. we connected the line from the tb to the vac port. the car wanted to start, but was ragged so he shut it down. others items don't seem right too. heres dave's diagram. i wish i could find the "Dr's".
Attached image(s) |
championgt1 |
Jan 26 2008, 03:26 PM
in d's diagram the aar line should run to the port with the black elbow on the fitler housing. currently the oil fill tower vent is on the fitting. this line should relocate to the a fitting on the plenum?
brp986s |
Jan 26 2008, 04:30 PM
the upstream aar port (pointing to the right) needs filtered air (no vacuum), however you want to do it. Those 2 filter housing positions are equivalent. The downstream side of the aar goes to the left rear vac port on the plenum along with the cold start valve. darlings pic confuses me because it looks like the case vent goes to what on my '76 would be a plenum vac port. your case vent looks ok though. I took off my decel valve and therefore plugged the 2 plenum vac ports on the front right. But, I can't see how everything else is hooked up on your engine. good luck.
rhodyguy |
Jan 26 2008, 08:47 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the vaccum hoses were a mess, hookup wise. we replaced them and put them on in the fashioned as outlined in george's diagram. found it in a search. problem persists. jack and i were brainstorming. a few more details came to light, and we may have solved the problem.
the car is hard to start. when it does it's straight to 3k+ with the throttle plate in the fully closed position. the fuel pump runs continously when the key is turned to the first position. not 5 seconds and off. jack told me the car backfired just before the idle issue. "stack (thru the tb) or out the muffler?". back up thru the tb possibly resulting in damage to the TPS or it was jammed out of it's proper setting. our guess is the ecu is seeing a signal for near or wide open throttle. he came by my place after i had left and picked up a TPS and a harness plug end that had been modified with 2 test leads. he'll test the TPS settings and recal it, replacing if ness. it was a good learning experience for the both of us. time well spent. brad ander's site was extremely informative. k |
championgt1 |
Jan 26 2008, 09:19 PM
Kevin thanks again for all your help. I agree it was a great learning experience. I am beat for today, but I will be checking resistance on the TPS switch tommorrow. Hopefully the switch will be bad and then the problem will be fixed. (IMG:style_emoticons/default/biggrin.gif)
Kevin you were a big help and I owe you big. |
Bleyseng |
Jan 26 2008, 09:34 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
The PCV connects to the plenum port
AAR valve connects to the air filter port Whats connected to the plenum port? 3k idle is usually too much air coming into! misconnected hoses is my guess... I think if the TPS is stuck to WOT it would flood the engine (too rich) as you need the extra air to get that idle rpm |
championgt1 |
Jan 26 2008, 10:46 PM
Dave_Darling |
Jan 27 2008, 01:34 AM
3K RPM cannot be caused by just a sensor reading incorrectly. You do have air going in there somewhere; probably a large vacuum leak.
--DD |
rhodyguy |
Jan 27 2008, 08:19 AM
note the fuel pump running all the time issue. brad's writtings on the tps, and one of it's functions leads me to suspect the tps. we shall see.
one of the plenum ports had nothing connected to it. as pictured, the vac adv port had no hose, #3 in the diagram. #17 on the aar valve was unconnected (pictured). #8 was connected to the filter housing port for #17. the decel hose #6 was connected to the F shaped fitting for #8. the various vapor hoses were either non-existant and the ones that were there were hookedup incorrectly. the F fitting i had on hand is marginal, jack will need to source one. a finger wipe in the tailpipe came out heavily sooted. pig rich. like a set of webers that are set up wrong or having excessive fuel pressure. we'll see what jack discovers today. something else...note the big herky helper throttle return spring on the tb plate shaft. the tbs i have at home don't have them. it that a late, late tb version? interesting. the previous owner had the engine rebuilt at well known shop on the eastside. the way the fi and various hoses were configured was the way they sent the car out the door. there are some pretty disinct difs in george's and dave's diagrams. note #7 and #8 in g's vs d's. |
Bleyseng |
Jan 27 2008, 10:46 AM
3K RPM cannot be caused by just a sensor reading incorrectly. You do have air going in there somewhere; probably a large vacuum leak. --DD yup, time to look for a vacuum leak (IMG:style_emoticons/default/agree.gif) thats a late 73-74 style TB with the dual springs. |
JeffBowlsby |
Jan 27 2008, 01:12 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Kevin/Jack...
I think its great you guys are putting your heads together to slay this dragon. After reading through this post here is what I can offer at the moment: I can only assume that you have checked every component, every vacuum line and everything check out. Valves adjusted, dwell and timing correct etc. The high idle is almost surely (99.999%) a vacuum leak or leaks, downstream of the throttle valve, supporting what others have suggested. All you can do is check source for an intake manifold leak. Is the AAR stuck open? TB gasket airtight? Injector seals airtight? Runner-air plenum gaskets tight? I have attached the vacuum hose diagrams I use for my 74 cars, also found on my website, if I recall they are subtly different than either Dave or Georges. I have another version not yet online, but it only swaps two of the decel valve hoses. As far as the continuous fuel pump condition, I understand that circuit is controlled by the ECU. If the engine does not start or is stalled the fuel pump should shut down after a couple seconds. So if its running continuously I would suspect the ECU. PS the TPS wont have much resistance, it only is a continuity switch. Check the idle contacts for on/off and of course the TPS calibration, and then check for what is 21 clicks during acceleration. Since its only continuit, you can verify ever function with an ohmmeter. Attached thumbnail(s) Attached image(s) |
championgt1 |
Jan 27 2008, 05:10 PM
Well I tested the TPS today with an ohm meter and I believe it checks out fine. Looked at all the connections again and then pulled out the PCV. The PCV has a small gasket that broke apart in my hands as I took it out. So I guess I will be tracking down a PCV and put it all back together and try it again.
Jeff, thanks for the diagram. Question is why are there so many diffrences in all the different vacuum diagrams for the same year/motor? (IMG:style_emoticons/default/confused24.gif) The only good thing about this whole mess is I am learning a (IMG:style_emoticons/default/stromberg.gif) load about D-Jet. (IMG:style_emoticons/default/biggrin.gif) |
BiG bOgGs |
Jan 27 2008, 05:24 PM
The Bogus One Group: Members Posts: 452 Joined: 25-September 04 From: Ft. Myers, FL 33967 Member No.: 2,829 Region Association: South East States |
Ditto on the air leaks. When I was trying to track down a high idle problem on my 76 2.0 D-jet I found my problem to be the seals between the plenum and the runners. 8 hose clamps later and she purred.
Jim |
SLITS |
Jan 27 2008, 05:38 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The plenum itself can be cracked and leak .... especially around the two support tubes.
Checked the timing? Hard start & high idle = well advanced timing Constant running fuel pump = check the fuel pump relay also for stuck closed contacts. |
rhodyguy |
Jan 28 2008, 07:46 AM
you guys rock. jack, i fell asleep after dinner last night and will call you this evening. i'll go thru my stuff tonight. first thing, swing by and pick up a known to be good relay and you'll eliminate that ? straight away. it'll thake about 30 seconds. then try jeff's diagram. there aren't too many difs to the way things are currently "hosed". haha. don't forget to call george.
k |
rhodyguy |
Jan 28 2008, 08:45 AM
just found. PVC-opens and closes nicely via oral vacuum. NEW tb gasket. lots-o AARs. lots-o relays, one HAS to function. r&r the one in the engine relay board and see if the pump turns off. lots-o plenums, that one we had at your house had everything on it. came off of a good running 74'. put on your tb. get new inj seals, and intake to head phenolic gaskets. i suppose you could seal the replacement plenum openings, duct tape?, and put a vac on it to double check for leaks prior to install. i'd just start new and go forward at this point.
ps was the broken gasket you told me about last nite the cork one on the base of the oil fill tower? got a new one of those too. k |
Lo-Fi Version | Time is now: 6th June 2024 - 10:06 PM |
