Rear axle removal |
Rear axle removal |
whitey |
Jan 29 2008, 10:00 PM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
What is the procedure for removing the rear axles. Are they actually driven out?
So.Cal.914 |
Jan 29 2008, 10:07 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
The axle or the half shaft?
SirAndy |
Jan 29 2008, 10:34 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The axle or the half shaft? (IMG:style_emoticons/default/agree.gif) the complete axle can be removed by unbolting the CV joints on each side ... if you're talking about the half-shafts, you'll have to remove a circlip (sp?) and then remove the CV ( (IMG:style_emoticons/default/smash.gif) ) (IMG:style_emoticons/default/bye1.gif) Andy |
KaptKaos |
Jan 29 2008, 11:31 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
If your CV bolts are stock, you will need a triple-square socket to get the bolts off the flanges on the trans.
Outboard, you need a GINORMOUS socket to get the nut off of the axle at the hub. Anyone know the size off of the top of their head? Undo those and you can pull the axles out pretty easily. |
Dr. Roger |
Jan 30 2008, 01:54 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
If your CV bolts are stock, you will need a triple-square socket to get the bolts off the flanges on the trans. Outboard, you need a GINORMOUS socket to get the nut off of the axle at the hub. Anyone know the size off of the top of their head? Undo those and you can pull the axles out pretty easily. My "off the top of my head" guesstimation is that it was about a 1 1/4" or 1 3/16" socket. Metric to SAE conversion. =) |
whitey |
Jan 30 2008, 02:00 AM
Thanks much...
HAM Inc |
Jan 30 2008, 08:44 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
If you have to use a hammer to remove the stubs from the hubs, remove the calipers first. Otherwise you run the risk of side loading the caliper mounts. This will crack them, thereby ruining the arm.
BTDT. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:09 AM |
