4 Pages V  1 2 3 > »
> Peter's Progress
pjf
post Mar 21 2008, 07:37 PM
Hi All. I've been around for awhile and even made a few posts but I finally got around to starting this restoration thread. My only claim to fame I would say is I was the guy who loaned Willam Harris some beat up steel wheels to finish his paint job. Still don't know why he returned them in favor of his pristine Fuchs.... Anyway, more years back than I'd care to admit I got the idea to restore a 914 and convert it to electric. I've worked on cars on an off and even graduated from the Somerville High Adult Ed Welding Night Course so I figured I'd go for it. A fairly ignorant Ebay winning bid later and I found myself the owner of a 76 from Texas. When the owner said that the right side door had a "latch problem" and the door wouldn't open I figured simple door repair, right? This was before discovering 914World and all the great information here. Things like don't buy 914s that have doors that don't open and don’t get POR-15 on your hootus. The thread by Michelko particularly inspired me to tackle the right side long. You guys are great and I want to thank everyone for their very helpful posts. (I got a “rebate” from the seller by the way).
Anyway here’s the car stripped down. As you can see space is no problem.
pjf
post Mar 21 2008, 07:52 PM
pjf
post Mar 21 2008, 08:02 PM
Here's the worst first. The right side long is in tough shape. I have pictures of it opened up so you can see the extent of the rust. As far as I can tell, a leaky rear window caused a lot of the damage here and in other areas. The good new is that the hell hole isn't that bad.
pjf
post Mar 21 2008, 08:04 PM
pjf
post Mar 21 2008, 08:07 PM
The left side long. The jackpost is gone but this side is actually in better shape than the right believe it or not.
pjf
post Mar 21 2008, 08:08 PM
pjf
post Mar 21 2008, 08:12 PM
The floor looked great until the tar came up and then you could see the damage from the pooling of the water from the leaky rear window. The bottom edge of the longs and rear firewall are in pretty good shape considering.
pjf
post Mar 21 2008, 08:13 PM
pjf
post Mar 21 2008, 08:16 PM
The hell hole has surface rust as you can see and there is some patching to do in the corner at the rear firewall but some decent metal here.
pjf
post Mar 21 2008, 08:18 PM
pjf
post Mar 21 2008, 08:19 PM
Sail panels need work as you can see.
pjf
post Mar 21 2008, 08:21 PM
pjf
post Mar 21 2008, 08:22 PM
pjf
post Mar 21 2008, 08:26 PM
Last but not least are the trunks. The usual rusty rear and a decent hole in the front to fill.
pjf
post Mar 21 2008, 08:28 PM
pjf
post Mar 21 2008, 08:30 PM
pjf
post Mar 21 2008, 08:34 PM
Before tearing into the longs I welded up some door braces and put two pieces bridging the windsheld and rear rollbar. Before doing this I was able to open up the right side door spacing a bit with jacks. The left was OK.
pjf
post Mar 21 2008, 08:35 PM
Van
post Mar 21 2008, 08:59 PM
Great idea to put those door hinge-to-seat belt braces in!
pjf
post Mar 21 2008, 09:25 PM
Thanks. Hopefully, the bracing will hold thing in position. I cut a metal rod that fits between two marked points so I can check the door opening. So far so good. The right side long was the first thing I worked on and its just about done. Tommorrow I'll try to post up to where I currently am with it.
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 2nd April 2026 - 02:54 PM
