OT wow I finally finished the engine swap in my 2001 ranger |
LarryR |
Apr 19 2008, 08:31 PM
Senior Member Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 |
Wow what a relief! About 5 or 6 months ago I bought a 2001 ranger with a toasted engine in it cheap ... I thought cool I will just swap out the engine and sell it for some extra dollars to spend on the 914.
Well here it is 5 or 6 months later finally done. What a pain in the a$$ to work on. I have swapped out probably 40 ish engines over the years but this one is bar none the biggest pain in the but to work on. Everything is a squeeze. Almost nothing is easy to get to. To top it all off Murphy was really messing with me on this one. I had purchased a 2600 mile engine from the bone yard so I just dropped it in there without changing anything. Well first screw up was that since the engine was from a much newer truck it did not have the same motor mounts ... very close ... close enough to look the same by eye... but after wrestling it around and getting it in there I realized that it was about 1/2 inch forward of the old mounts... pulled it back out and swapped the mounts ... Next PITA... every other car with an automatic that I have ever worked on had a 1/2 inch or so slide back for the torque converter to allow you to get it out of the way while bolting the trans to the engine... not this POS you have to align the torque converter bolts to the flywheel while dropping it in the car ARGH! Now for when Murphy REALLY came into play... I got it all in there everything bolted up go to start the truck ... nothing... wont even try... hmmmm.... ok so I check my wiring on the starter (looks good) , neutral safety switch (looks good) Sh*t what can it be... So I go buy a manual for the thing and start through the diagnosis route ... hmmm all the volatages are wrong almost everywhere... OOPS!!! the harness has to be swapped out which means all the front engine accessories have to come back out so radiator shroud everything back out (IMG:style_emoticons/default/WTF.gif) So the truck proceeds to sit for several months b/c I hate undoing work... but last weekend I pulled all that apart and today I put it back together with the old harness and voila it fired first touch of the key. So the moral of the story I guess is always use your old harness and mounts, never work on a ford ranger with a 4.0 v6 and I guess thats it ... end of rant... (IMG:style_emoticons/default/beer3.gif) |
LarryR |
Apr 19 2008, 09:36 PM
Oh side note I guess the alarm bells should have gone off when the guy told me that 3 separate shops said they wanted 4K labor to swap out the engine!!! I just thought it would be a 4 or 5 hour job. I have close to 50 hours work into it now .... So I guess 4K was a pretty reasonble rate.
smontanaro |
Apr 20 2008, 01:19 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
atsealevel914 |
Jan 3 2009, 05:54 PM
Member Group: Members Posts: 103 Joined: 31-January 04 From: Miami,FL Member No.: 1,618 |
I think there are diesel engines removed from mazdas from japan that will mount right up to your chassis. no ecu required. |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:15 AM |
