Learned something new, Djet ignition |
r_towle |
May 19 2008, 09:02 AM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I was fixing a volvo p1800.
This is a 2.0 liter motor with Djet (1973) the only major difference is the TPS is two circuits instead of three, the rest is the same...the MPS is calibrated for the volvo...but its still an MPS. (the plenum is alot bigger than ours) So, I was getting a weak and very erratic spark...it would work then it would not...it was driving me crazy. The final test was this. Take a spare plug. Using a cable ground the plug and use a plug wire to connect this plug to the coil directly. With a screw driver, open and close the point (basically the screw driver IS the points in this test...just short out the two sections of the points till it sparks) So, this was providing me with a random spark...hmmm I found that the ground lead, or ground strap that ties the advance plates together was faulty.. Even though it looked visually ok...it was weak and somehow broken. I took it out and pulled on it..its still attached...but its not working correctly. I happen to have another set of advance plates...plopped those in and everything was fine. The reason I share is this took me a long time to track down... It would work, then stop..then run on two cylinders etc. I checked and replaced everything..relays, FI points, you name it... It was a lousy ground strap inside the distributor that was at fault.. Rich |
Bartlett 914 |
May 19 2008, 09:08 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
That is a good problem!
It doesn't matter if it electronics or automotive, ground problems are difficult to find (at least by measuring). We often speak of checking grounds here but that is one I think most all of us would have missed. Thanks for sharing. |
toon1 |
May 19 2008, 09:23 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Good job diagnosing the prob.
championgt1 |
May 19 2008, 07:39 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
I have a 2.0 djet. Good info to know.
Rand |
May 19 2008, 07:50 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I had the same issue. Started running like crap then wouldn't run at all, but would try to fire now and then. Checked spark... Was weak / yellow at plugs. Was strong / bright blue at coil. That quickly narrowed it to the distributor.
Sure enough, that little braided ground came loose on one of the plates. To get home, I ran a temporary ground from a plate to the dizzy body (one of the plates is already grounded to dizzy body, other gets ground via wire - so ran wire from that plate). Fired right up. Not a bad idea to carry some wire, connectors, and a crimp tool in your onboard toolkit. |
markb |
May 19 2008, 07:52 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
zymurgist |
May 20 2008, 03:51 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
(IMG:style_emoticons/default/clap56.gif) I never would have thought of that...
Cap'n Krusty |
May 20 2008, 04:13 PM
Pretty common problem. I used to stock the plates (if the strap is worn out, so's the plate). NLA. The Cap'n
Rand |
May 20 2008, 04:29 PM
Question, Cap'n...
I am curious, what wears out on the plates themselves? Surface wear, inhibiting smooth movement? What if they have been kept clean and lubed? Still? Thanks. |
Cap'n Krusty |
May 20 2008, 06:00 PM
They get sloppy, causing substantial dwell variation. The Cap'n
r_towle |
May 21 2008, 11:26 AM
just added to my list of the top things to look for now...lol
Rich |
Lo-Fi Version | Time is now: 9th June 2024 - 03:00 AM |
