1.8 to 2056, plug for back up lights |
mattp |
Jun 25 2008, 08:27 PM
Member Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 |
I have a 75 that I am converting from a 1.8 to a freshly built 2056, the back up light plug is connected to the harness off the 1.8, what/ how do I connect it when I put the 2056 in? I am also going with carbs not FI.
HELP!! |
Brando |
Jun 25 2008, 09:07 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
I believe the wire for them is grey with a blue stripe. Not sure where it plugs in though.
rhodyguy |
Jun 26 2008, 08:46 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
what? that circuit should be contained in the wire loom that goes to the starter. independent of the fi harness.
mattp |
Jun 26 2008, 01:44 PM
yeah, the wire loom connects the following:
starter, back up light, relay board, grounds (on case), a relay on the firewall and the coil. Anyone know exactly how they go? |
Cevan |
Jun 26 2008, 06:29 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
If your 1.8 had the stock FI, then that loom is the ignition harness and it goes from the 12 pin connector at the relay board to the coil, oil pressure switch and half the dual relay, and part of it splits off to the starter and backup switch. According to my Haynes manual, those two wires from the backup light switch come from pin #2 and pin #4 of the 12 pin connector on the relay board.
I can't think of how'd you could avoid using that ignition harness. You could probably modify it by removing the dual relay holder and acompanying wires. |
mattp |
Jun 26 2008, 07:38 PM
do I need to do anything with the other 1/2 of the dual relay and it's accompanying wires?
Cevan |
Jun 27 2008, 01:33 PM
do I need to do anything with the other 1/2 of the dual relay and it's accompanying wires? I think you could just zip tie it together and tuck it out of the way. Depends if you want to preserve it for future use. Some might say to just cut those wires off and cap them. |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:00 AM |
