Carlitos Way |
I did it MY WAY ![]() ![]() ![]() Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California ![]() |
I am reading that the head bolts should be replaced to do a head gasket job. Can anyone explain why this is a recommended procedure?
Thanks, C:> |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
Depends on the car, but most modern head bolts are designed to stretch when they're torqued to spec. The stretching lets them hold the torque better than a hardened bolt, but means they need to be replaced after each use. It's usually not that big an issue since they aren't (shouldn't be) very expensive and these days not that many cars ever get their heads removed and replaced before they hit the scrapyard.
Lo-Fi Version | Time is now: 11th July 2025 - 01:21 PM |
