Best Plug Wires |
Best Plug Wires |
germaneighter |
Sep 17 2008, 05:53 PM
Member Group: Members Posts: 130 Joined: 9-August 05 From: Tulsa, OK Member No.: 4,563 |
What are the best plug wires?
dg |
ArtechnikA |
Sep 17 2008, 06:56 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
sww914 |
Sep 17 2008, 08:01 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
I agree, Magnecors are a good value.
blitZ |
Sep 17 2008, 08:05 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I've had the Magnacore and Beru. I like the Beru better. I had some funky missing full throttle in 5th at 4k plus rpm, never could nail down the problem. Once I switched to the Berus it was gone.
ArtechnikA |
Sep 17 2008, 08:10 PM
I've had the Magnacore and Beru. I like the Beru better. This is why the application is important. one thing I like about the Magnecore for /6 applications is that the connectors and air seals fit, work, and don't embrittle like the German rubber seems to. But I've never used them on a T-IV, so I can't tell what those'd be like. I assume they're different between the 2,0 and the others... I need a set of wires for the Subie and I'll try a set of Magnecore's there. I'd be astonished if there were Subie Beru's ;-) |
SGB |
Sep 17 2008, 08:18 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Magnacores did NOT work well for me either. They would not connect securely to the plug. I'm back to good ol Bosch, but I should try the Beru ones.
germaneighter |
Sep 17 2008, 08:49 PM
4 cyl 2.0 stock F.I. Crane Ignition Conversion What are the best plug wires? a quick search here on Magnecore will show you ;-) Is this for a T-IV, a flat-6, a Chevy, or what? I still think the answer is Magnecore, but give us a little more to go on... |
germaneighter |
Sep 17 2008, 09:52 PM
Where is best (mail order) place to get Magnacore and/or Beru?
SGB |
Sep 17 2008, 10:24 PM
I'm always satisfied with Pelican parts.
blitZ |
Sep 18 2008, 06:40 AM
Where is best (mail order) place to get Magnacore and/or Beru? I have the exact same setup as you and used these wires. Paragon plug wires |
charliew |
Sep 18 2008, 10:50 AM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
You might check with lowbudget.com, AJ Simms, he's pretty straight and has the best quality parts for good prices. I know he has the type 1 wires not sure about type 4.
Lo-Fi Version | Time is now: 1st June 2024 - 02:36 AM |
