Welding question |
Welding question |
PeeGreen 914 |
Mar 22 2009, 10:17 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
So I am welding in the Tangerine Racing inner consol reinforcement. If I have the welder set on three it doesn't bite into the ear. If I have it set on four it bites but it blows holes in the new piece. I was able to get two holes filled and they are definitely welded on. However, I am wanting to know before I do more if going on the four setting will be right and not damage anything. Three just doesn't seem to cut it.
So.Cal.914 |
Mar 22 2009, 10:25 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I know this is going to sound silly but run a hundred foot extention for the welder and use #4 setting.
PeeGreen 914 |
Mar 22 2009, 10:28 PM
Really? (IMG:style_emoticons/default/confused24.gif)
Now what kind of extension cord are you talking about? |
PanelBilly |
Mar 22 2009, 10:43 PM
914 Guru Group: Members Posts: 5,816 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
If you turn it up to 4 can't you increase the feed rate to make up for the heat? |
brant |
Mar 22 2009, 10:49 PM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the extension cord is actually good advice.
or... I'd set it to 3 and then turn up the wire speed with the 3 setting more wire speed equals more heat for me. |
PanelBilly |
Mar 22 2009, 10:53 PM
I thought more wire reduced the heat?
So.Cal.914 |
Mar 22 2009, 10:57 PM
Really? (IMG:style_emoticons/default/confused24.gif) Now what kind of extension cord are you talking about? Between the wall and your welding machine. Cuts down on the amps making it to your welder. |
dbgriffith75 |
Mar 22 2009, 11:02 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
I know this is going to sound silly but run a hundred foot extention for the welder and use #4 setting. Really? (IMG:style_emoticons/default/confused24.gif) Now what kind of extension cord are you talking about? He's right... and it depends on the draw of the welder; but as a general rule of thumb the heavier the cord the better. If you just have a little home welder that runs off of 110, a 12 or 10 gauge extension cord should do it; if it runs off of 220 or higher, get your billfold out and be prepared to pay. Even a 25 ft cord can get expensive. |
PeeGreen 914 |
Mar 22 2009, 11:08 PM
Thankfully it is a 110 and I already have some heavy duty cords. Just needed to know what kind of cord. I have a 100 ft general garden type cord or two 50 heavy duty cords. I'll use one of the 50 footers (IMG:style_emoticons/default/beerchug.gif)
PanelBilly |
Isn't the longer extention cord going to blow the breaker?
sixnotfour |
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Attached image(s) |
PanelBilly |
Mar 22 2009, 11:17 PM
Instructions, aren't they like asking for directions, anti-manly?
sixnotfour |
Mar 22 2009, 11:20 PM
Ya But better than filling his tub full of holes. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/welder.gif)
brant |
PeeGreen 914 |
Mar 22 2009, 11:26 PM
(IMG:style_emoticons/default/piratenanner.gif) Thanks Jeff and others (IMG:style_emoticons/default/beerchug.gif)
PanelBilly |
Mar 22 2009, 11:28 PM
It would just burn back into the tip.
I guess I just start where I left it last and make little adjustments until I happy with the balance. Now I have to pull out some sheet metal and experiment. |
sean_v8_914 |
Mar 23 2009, 01:19 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
here are some tricks of the trade to help prevent burn thru:
CLEAN YOUR GROUND POINT BETTER. clean your weld area better. use a heat sink pc of copper or an AL backing plate to absorb some heat. put several clamps close to the area to suck out some heat. a stack of pennies under a clamp workds also. add small spot weld dabs to the surrounding area first to increase metal amount near area. this helps absorb heat. the 4 click number thing is voltage while wire speed controls amperage. increased wire speed increases amperage AKA heat to panel. |
sean_v8_914 |
Mar 23 2009, 01:21 AM
pre-heat the area with a torch. it does several things:
removes moisture burns away contaminants that cause poping |
PeeGreen 914 |
Mar 23 2009, 01:22 AM
So are you saying if I have it on four but slow the wire speed that may help as well? The clamp thing makes sense as well. Thanks
sean_v8_914 |
Mar 23 2009, 01:39 AM
not that simple. teh wire speed and voltage must match teh conditions. use teh guide as posted. back off on wire speed by 10%. your suspension ear is rusted from teh inside. the rust is iron oxide. teh oxigen expands violently. the pop blows the molten puddle away. I think the tiny spot welds to build up some material will be teh trick for you. welding to rusty metal is never text book proceedure.
the extension cord will make your welder put out less power on teh #4 setting but amperage will increase proprotionately...maybe, try it. my Miller digital welder is not fooled by such shenanigans. |
Lo-Fi Version | Time is now: 7th June 2024 - 12:05 AM |
