Foglight Switch, repair and pictures 3 |
76-914 |
Apr 9 2009, 04:53 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
This is a close up of the "HOT" pin. Look at the base of spade closely. Notice the puddle around the base. The metal got so hot it sunk into the bakealite and the thimble lost it's grip breaking contact w/ the copper strip.
The solution was simple: just a spot of acid core solder from the thimble to the copper and then file it down for proper clearance. The trick was how to NOT melt the bakealite any further when soldering. I settled for this and it seemed to work. I emersed the other half in a small bag filled w/ ice & water to act as a heat sink. The whole job took < an hour once I got the switch on the bench. Easy job! |
smontanaro |
Apr 9 2009, 05:54 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Why acid core solder and not rosin core?
Lo-Fi Version | Time is now: 31st May 2024 - 05:54 PM |
