Scott S |
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 ![]() |
Hi All -
Is anyone remaking/selling the 9146GT firewall mounted shoulder harness mounts? Thanks! (IMG:style_emoticons/default/beerchug.gif) Scott S Attached image(s) ![]() |
nein14 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 839 Joined: 6-February 03 From: USA Member No.: 262 ![]() |
hint try mc master carr
Scott S |
Yep, been there. This is as close as I could find:
http://www.mcmaster.com/#pull-handles/=1kq0z3 I do not even remotely trust them as they are all drilled and internally threaded vs being a threaded rod with a nut on the end. |
rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
Do you really want to risk your life using door pulls (IMG:style_emoticons/default/sad.gif)
Scott S |
Just found the fabrication instructions on the GT site... (IMG:style_emoticons/default/beer.gif)
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 126,527 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
What GT site? Armando's? GT Racing?
T.C. |
Scott S |
Hi TC -
- over at Armandos... I will look up the exact link (I always forget about how much stuff is on his site!) |
carr914 |
Scott, I go to Armando's site regularly. I just looked and saw the set that Armando has for his car, but I didn't anything about fabricating a set.
T.C. |
ChicagoPete |
Member ![]() ![]() Group: Members Posts: 227 Joined: 10-January 05 From: Lake Forest,IL Member No.: 3,427 ![]() |
For sure you can fab these things up...but, if you are looking to purchase them they are most certainly available on:
http://www.mittelmotor.de/content_e/angebo...es.asp?catID=12 I have never seen them available in the US. Don't forget that when you are installing these there should be a square plate welded onto the firewall where these are secured. Peter Attached image(s) ![]() |
Scott S |
Hi TC -
Here is the link - scroll down to the comments below the picture menu... http://www.pbase.com/9146gt/factory_original_9146_gt_parts |
Lo-Fi Version | Time is now: 31st July 2025 - 02:29 PM |
