rear sway bar, which way |
Tman914 |
May 21 2009, 07:16 PM
Member Group: Members Posts: 136 Joined: 9-December 04 From: "Livermore, Ca" Member No.: 3,247 Region Association: Central California |
OEM rear sway bar which way does it go ends up Or down where the links hook
up at its fix both ways |
Tman914 |
May 21 2009, 08:12 PM
does any one know this
detoxcowboy |
May 21 2009, 08:22 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
on my 74 2.0 with oem rear sway bar the links drop down from the sway bar to the shock mount.. rear drop links.. hope this is what you were asking..
SirAndy |
May 21 2009, 08:45 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
OEM rear sway bar which way does it go ends up Or down where the links hook up at its fix both ways If installed correctly, the droplinks are parallel to the shocks when the car is on the ground. If you flip the bar, the droplinks don't line up with the shocks ... (IMG:style_emoticons/default/bye1.gif) Andy |
Tman914 |
May 22 2009, 12:30 AM
ok thanks
Lo-Fi Version | Time is now: 23rd May 2024 - 03:24 AM |
