Engine |
Engine |
Niklas |
Jul 4 2009, 10:41 AM
Porsche 914 Sweden Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
I have bought a brand new NOS 1800 cc engine VW type 4 called AP with 68HP.
The engine have dual Solex 34. It is all new never used. If I want to use it in my 914 what should I do with it? Change what to make more horsepowers??? Camshafts - heads - carbs ?? Give me some tips. |
Todd Enlund |
Jul 5 2009, 12:58 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
The AP case is from a VW transporter. The dipstick will be in the wrong location for a 914, but that can be worked out.
You'll need to change the FI fuel pump to something appropriate for carbs. To get more power out of it, well... it's a bus engine. Almost anything you do to it will get more power out of it... it's 7.3:1 compression, so a good set of pistons/cylinders can bump that up. A better cam will help it breathe. If you have kronor to throw at it, cylinder heads... either a lot of work on the ones you have, or a set from a 2.0 914 engine. Weber IDFs will breathe better than the Solexes. Answers are slow this weekend because the Americans on the board are having a holiday (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 9th June 2024 - 03:55 AM |
