For all you K&N devotees, A little comparison ............. |
Cap'n Krusty |
Sep 18 2009, 11:14 AM
Here are some comparison photos and a little math for your viewing pleasure. I might mention that you can SEE THROUGH the K&N, down in the folds.
This particular part fits a 2003 MB C320 Kompressor coupe. The K&N has 128 square inches of filter media, the Mann has 1752 square inches! That's over THIRTEEN TIMES the filtering area! Attached image(s) |
McMark |
Sep 18 2009, 11:21 AM
So? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/happy11.gif)
But really, thanks for the comparison. Makes is pretty obvious. |
ghuff |
Sep 18 2009, 11:34 AM
This is certainly not what I expected down here. Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
That less of a restriction has to come from somewhere, it comes from filtering (IMG:style_emoticons/default/smile.gif)
Most of my friends with turbo cars literally just put wire mesh over the inlet. Then again they swap turbos ever season. |
Chris Hamilton |
Sep 18 2009, 11:41 AM
Senior Member Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
Just eyeballing the things doesn't prove how well they work or don't work. Do you have some way of measuring the amount of particulate each one catches in a controlled environment?
blitZ |
Sep 18 2009, 11:49 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Here is another filter test. I use the Apexi which filters best. The K&N are average and not worth the hype.
Filter Test |
Rod |
Sep 18 2009, 11:59 AM
Senior Member Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
Here is another filter test. I use the Apexi which filters best. The K&N are average and not worth the hype. Filter Test Do you use an Apexi in your 914? If so which one?? |
blitZ |
Sep 18 2009, 01:00 PM
I just use a cone filter with an intake from Home Depot Racing.
Attached image(s) |
ConeDodger |
Sep 18 2009, 02:38 PM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I just use a cone filter with a intake from Home Depot Racing. Trekkor??? Is that you? (IMG:style_emoticons/default/poke.gif) |
Cap'n Krusty |
Sep 18 2009, 02:50 PM
Just eyeballing the things doesn't prove how well they work or don't work. Do you have some way of measuring the amount of particulate each one catches in a controlled environment? There are plenty of studies out there. To pass the same amount of air through a smaller area, the restriction has to be reduced. Fewer square inches of media, larger passages through that media. To increase the amount of air passing through, you have to increase those holes to an even larger size. In this case, you can SEE through the filter media. That means relatively BIG stuff can get past it. The Cap'n |
Porcharu |
Sep 18 2009, 03:57 PM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
I used to wipe fine sand like stuff out of my intake pipe on my K&N 'filtered' GTI. Every car that I have worked on that had a K&N had dirt on the throttle body. My old Mustang had one and has pretty serious cylinder wall wear at 25,000 miles (I had it apart when I wiped a few the rod bearings when the oil pump drive snapped.)
Steve Just eyeballing the things doesn't prove how well they work or don't work. Do you have some way of measuring the amount of particulate each one catches in a controlled environment? There are plenty of studies out there. To pass the same amount of air through a smaller area, the restriction has to be reduced. Fewer square inches of media, larger passages through that media. To increase the amount of air passing through, you have to increase those holes to an even larger size. In this case, you can SEE through the filter media. That means relatively BIG stuff can get past it. The Cap'n |
McMark |
Sep 18 2009, 04:09 PM
I run a K&N, a Tornado, and fuel line magnets to maximize my engine.
Attached image(s) |
VaccaRabite |
Sep 18 2009, 04:25 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
For those of us using dual carbs, what aside from K&N is there to use as an air filter? Is there even a paper element option for us?
Zach |
ArtechnikA |
Sep 18 2009, 04:41 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
For those of us using dual carbs, what aside from K&N is there to use as an air filter? Is there even a paper element option for us? Yes, but you won't like it... /6's used a paper filter with dual carbs 40 years ago; 356's and 912's long before that. The filters are readily available but you'd have to do some fabrication for the housing. |
PeeGreen 914 |
Sep 18 2009, 04:45 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Just make sure your K&N is well oiled. One of the big causes for crud getting past is because of not maintaining them properly.
Unfortunatly they are about the best we have for our carbs but if you use rain hats and oil them and clean them often they will work well. |
monkeyboy |
Sep 18 2009, 05:53 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Outerwears help a lot too. I have run a K&N on my desert toys since I got them. Always with an Outerwear on them, and I have never seen anything get past the filter. My buddies that don't run them get grit in their engines often.
I know that the K&N's don't filter that well, so I use the prefilter. It's a lot easier to clean than the K&N too. |
Borderline |
Sep 18 2009, 06:25 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
The K&N filters don't even increase the HP. A recent article in Grassroots MS has an article where they dyno test an engine and try different changes. When they put on the K&N filter they got miniscule improvement...pretty much noise level on the dyno. Anyway, they proclaimed a HP increase. I lost a lot of respect for them, but I guess they gotta keep the advertisers happy.
gothspeed |
Sep 18 2009, 06:26 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Great thread!!! ...... I have done flow tests of my own using paper vs K&N ....... the K&N produced zero RWHP gains over paper in my test vehicle ....... even though on the flow bench they outflowed paper by a mile ....... anyway all my tests show is the factory sized the paper elements adequately to where K&Ns did not make a difference for the better.
pktzygt |
Sep 18 2009, 06:51 PM
Member Group: Members Posts: 328 Joined: 20-March 07 From: Chesapeake, VA Member No.: 7,611 Region Association: MidAtlantic Region |
I read that Grassroots article, it was a BMW 335 i think. It always seems like certain mods that make power on one car don't make power on another, especially ones with new-fangled computers. I'm going to keep buying K&N's just because they are made in so many sized that I can get one to fit anything I need it to.
Ohh, and Mark... I found a tornado at the Pink-N-Pull once stuck inside the intake pipe I needed for my truck. I couldn't get it out without destroying the rubber pipe. I was pissed. The truck it came out of had the entire interior spray painted yellow and white and blue........seats, carpet, dash....everything. |
balljoint |
Sep 18 2009, 08:13 PM
914 Wizard Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
I run a K&N, a Tornado, and fuel line magnets to maximize my engine. You also hang out here. (IMG:style_emoticons/default/biggrin.gif) |
westgl |
Sep 18 2009, 08:40 PM
Newbie Group: Members Posts: 41 Joined: 14-November 08 From: Rogue River, OR Member No.: 9,756 Region Association: None |
I agree with Krusty,
Read the article that K&N puts out, it's on their site. It says that their filter's are only 80% effient, and are for racing applications only, like engines that will be torn down often!! I would rather use something that does what I'am paying for it to do, like actually filter 100% of the crap out before it sand blasts the insides of my engine. It's good, when you have to replace your filter, it's doing it's job. People who use K&N filters for the street are turning their engines into expensive Vacuum cleaners. Anyone with a K&N filter want to drive up and down my street? Because the street cleaners are on stike and it's starting to look like a beach out there. Sandy! Just my 2cents westgl |
Lo-Fi Version | Time is now: 10th June 2024 - 01:55 AM |
