Oil Pressure Sender Install, Thread Sealant? |
kconway |
Sep 25 2009, 12:26 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I need to put in a new oil pressure sender, I though I remember that it wouldn't work properly if you used teflon tape on the threads. Is this true? Do you install this dry?
Kev |
markb |
Sep 25 2009, 12:42 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Install it dry.
Gint |
Sep 25 2009, 07:13 AM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
URY914 |
Sep 25 2009, 07:24 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Tapered threads, no sealent needed.
Bartlett 914 |
Sep 25 2009, 08:16 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Tapered threads, no sealent needed. The general consensus here seems to be not to use tape (or lubricant) I really don't understand why not. Tape is not a sealant. It is to prevent the threads from galling allowing it to tighten tighter. Why is this any different from tapered threads in plumbing? There you will use a Teflon tape or pipe dope of some kind. All of these are thread lubricants. |
VaccaRabite |
Sep 25 2009, 08:31 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I put case sealant on it just like all the other pipe-threaded plugs I installed on my engine.
Teflon tape is bad because it degrades with fuel or oil or continued heat, and can permit a leak. Zach |
Bartlett 914 |
Sep 25 2009, 08:50 AM
markb |
Sep 25 2009, 09:00 AM
I believe the sender needs to ground to the case to operate correctly.
hcdmueller |
Sep 25 2009, 09:14 AM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
The sender has to ground to the case. I have the relocation kit so I used teflon pipe sealant and grounded the sender separately. |
DBCooper |
Sep 25 2009, 09:18 AM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
The sender needs to ground, so both sealant and tape cause problems. Worse, since they're tapered threads that slick Teflon tape makes it REAL easy to overtighten the fitting so much that you strip the threads. And there's no oversized sender, so it's not feasible to re-tap the threads the next larger size. More in magnesium cases, but still a serious bummer.
IronHillRestorations |
Sep 25 2009, 01:52 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I use a small amount of permatex aircraft sealant. They are tapered threads (dimensionally the same as 1/4" NPT) so in theory they should seal when you tighten them, the problem is when the bore has had a sender over tightened.
r_towle |
Sep 25 2009, 02:47 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
when using a remote setup for a guage/idiot light....can you pleast post some pics of how you "grounded" the sensor.
I have done it, but I am hoping to see a more elegant solution. Rich |
76-914 |
Sep 25 2009, 04:34 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Tapered threads, no sealent needed. The general consensus here seems to be not to use tape (or lubricant) I really don't understand why not. Tape is not a sealant. It is to prevent the threads from galling allowing it to tighten tighter. Why is this any different from tapered threads in plumbing? There you will use a Teflon tape or pipe dope of some kind. All of these are thread lubricants. Mark is 100% correct. It's a lubricant. So is a bar of soap. Get your mind out of the gutter! As Mark mentioned; pipe threads are tapered. (Know the ratio? It's 1" per 12ft.) The dope, tape or any other lubricant just allows the tapered threads to perform their original function with less resistance. Teflon differs from other types of lubs in that it can be used as a sealant. When there is a leak at a tapered thread joint, it is a funtion of the threads; not the pipe dope. Pipe dope will not seal "shit". However, with enough teflon tape applied, threaded diameters can be increased in size. This is where Teflon tape gets a bum rap. Anything, I repeat anything is dangerous in the hands of the ignorant. Notice I didn't say idiot. There are specific tapes designed for certain jobs and they are color coded. Pink is for gas. Also, the good stuff is thick. Not like that cheap stuff you find in hardware stores. And because it is gauged you know to use no more than 3 1/2 wraps! Do you know where to begin wrapping? At the starting threads. And don't put it on backwards. Yes, it matters. Clockwise, the same direction as the threads. Do it the other way and......."Oh my gosh. What happened to the tape. It came off!" As far as heat being a problem; I literally solder and braze (700F-1100F) within 1-2 inches of teflon tape threaded joints (and have done so for 30 yr's) with no resulting leaks. (remember the tape has already completed it's job at this point.) I wouldn't hesitate to used it any auto application; or Permatex A/C sealant or a bar of soap or a drop of oil (except on PVC, oil or petroleum based pipe dopes will soften PVC) Life is like a box of chocolates. Thats about all I have to say. |
Al Meredith |
Sep 25 2009, 07:27 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I believe in every rebuild kit there is a crush casket that is to be used between the oil pressure sender and the case. Please correct me if I'm wrong. Al
VaccaRabite |
Sep 25 2009, 10:51 PM
Mine worked with case sealant. I am using a paintball hose to remote locate a dual sender for the idiot light and the VDO pressure gauge. it is grounded to the case via the mount, which bolts to the case.
Works like a charm. Zach |
underthetire |
Sep 26 2009, 12:52 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I used a grease gun hose. Someone (maybe Krusty ) gave me the idea on here. Works like a charm. I then used a conduit strap to hold the sender down. Looks ok. Better than the hose clamp thing I think. Total cost was like 12 bucks vs the 40-50 for the VDO one.
Lo-Fi Version | Time is now: 10th June 2024 - 09:31 AM |
