WTB: Front sway bar end link - FOUND SOME!, basic adjustable Weltmeister type |
PlaysWithCars |
Oct 27 2009, 09:53 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Looking for a pair of the end links that come with the Weltmeister bars; the link between the adjuster and the a-arm. Anyone have a pair of these around the shop after upgrading to the "competition" style that are threaded on both ends?
Or, do you know if I can buy these separately somewhere? The only ones I've found are the style that can be adjusted with both ends still installed. I'm looking for a less expensive solution. |
jcd914 |
Oct 27 2009, 10:31 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I have a set.
I need to find 1 more lock nut and 2 more of the sleeve/spacers for the hiem joint end. You need 2 spacer/sleeves for each hiem joint if you are using stock swaybar tabs on the control arms. The bolt hole thru the hiem joint is 3/8" and the spacers step it down to 8mm. $25 shipped? Jim |
PlaysWithCars |
Oct 28 2009, 12:47 AM
Sounds good. PM me payment details. Thanks.
Lo-Fi Version | Time is now: 9th June 2024 - 05:15 PM |
