Door Handle, Removing |
elsargento |
Nov 21 2009, 05:52 PM
Newbie Group: Members Posts: 44 Joined: 9-September 06 From: Topanga, California Member No.: 6,802 |
Exterior door handle stopped working. I removed the panel and found a piece of plastic laying in the bottom of the door. Must be apart of the assy. that pushes against the fork to release the latch. I removed the allen screw trying to get the handle off. But there is a screw with an acorn nut that turns with the nut..
can't get it free. HELP! (IMG:style_emoticons/default/headbang.gif) |
URY914 |
Nov 21 2009, 06:42 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,980 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Both are common problems.
The plastic piece can be replaced. Pelican has the part for $17.99 or so. The spinning stud is another problem but can also be fixed with a drill and a sharp bit. After you drill it out you'll have to use a 6 mm bolt and nut. If your good with a drill or have a drill press you can counter sink the bolt into the mounting tab. After you break the mounting tab send it to me and I'll fix it for you. I'm having a UPC sale on my tab fix these days. The new price is $25.00 which is a hell of a savings over the standard price. Here is a pic....... Attached image(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 11:24 AM |
