Rear caliper adjuster, outer screw just spins, no piston movement |
davesprinkle |
Nov 29 2009, 04:12 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
So I just installed a replacement caliper. Went to set the pad clearance and I can't get the piston to move. The adjuster has no effect on the piston. The screw just spins with no effect. Can anybody offer any insight?
bfrymire |
Nov 29 2009, 06:04 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
So I just installed a replacement caliper. Went to set the pad clearance and I can't get the piston to move. The adjuster has no effect on the piston. The screw just spins with no effect. Can anybody offer any insight? Don't have personal experience, but Eric Shea had a lengthy posting about R&R of the rears, if my memory serves me right. Eric also has a link on his website about rebuilding that may offer some insights: http://www.pmbperformance.com/page/page/1925687.htm Hope this somehow helps. -- brett |
davep |
Nov 29 2009, 06:25 PM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The "replacement" caliper is in what condition? If it has been properly rebuilt, then the piston should move as you turn the adjuster. It sounds like the adjuster and the piston are not linked. The adjuster and piston are supposed to be linked by a friction ring on the body of the adjuster that sits in a groove in the piston. When it is out of position, I rotate the adjuster in the opposite direction until I hear it SNAP into place. If the piston is seized in the bore, you can pull the ring out of the groove easily enough. If the friction ring is too well lubricated, it can just spin in the groove; this is a pretty bad situation. Basically, the piston must move freely enough for the adjuster to work properly.
Lo-Fi Version | Time is now: 11th June 2024 - 03:39 AM |
