BMXerror |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 ![]() |
Does anybody know the size difference between the 1.7 and 2.0 heads where the cylinder slips in? Actually dimensions would be nice. Bore on the heads, or OD of the cylinders. Either one. Doesn't matter.
Also, is there a difference at the bottom too? I.E., is there a larger bore on the 2.0 case for the sleeves? Thanks in advance. Mark D. |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,757 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
Yes, it is different, but I don't know by how much. measure the OD of the 1.7 and the OD of the 2.0 and that will tell you. If you are using 1.7 heads on a 2.0 you have to have them cut for the bigger cylinders.
Zach |
Cap'n Krusty |
Top's different, the base of the cylinders is the same. The Cap'n
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Heads should only be done with the new cylinder in hand, allow about .015 over on the flycut.
It works, I've done it several times, but I'd try to find a set of 1800's first. |
Lo-Fi Version | Time is now: 13th July 2025 - 07:59 PM |
