Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
So after I had removed all the head studs from the case, I noticed a couple had come out real hard, as if something was wrong with the threads. After cleaning the threads of the stud, I couldn't thread them back in the two suspect holes.
I got a 12mmx 1.5tap and chased those holes. Now, the head studs go right in and they wiggle!! Even after I bottom them out, they can be moved relative to where they exit the case. Is the case shot? What did I do wrong? |
bam914 |
Member ![]() ![]() Group: Members Posts: 342 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None ![]() |
They should thread in tight like that. The only time you tap them is when you are installing ARP head studs.
Cap'n Krusty |
A standard tap, the one everybody has, is NOT meant to chase threads. Odds are, you've recut the threads and they're now too deep. The Cap'n
Cevan |
Seeing as I screwed up only one of the case halves, can I replace just the one case half, or are cases halves sort of matched to each other?
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,021 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Seeing as I screwed up only one of the case halves, can I replace just the one case half, or are cases halves sort of matched to each other? You should be able to have a threaded insert installed to save the case. Not sure what you might have if you tried to replace one side of the case. Cases are not that hard to find. I have a few extra ones. I would sell a whole case for $50. Bruce |
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
While you were cleaning the studs, did you notice aluminum trapped in in the threads on the studs that came out hard?
If so, that might explain your loose fitting stud/hole combo... Inserts are the only way to fix that, and don't use a hand drill. They need to be installed with precision machinery to ensure the studs don't cock. By precison, the case has to be held flat on the machined surface and either a drill or a mill comes in perpendicular to the machined surface to ensure the inserts are oriented correctly. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
And NO to using two different case halves. They are a matched set.
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
Take it to a machine shop and have them fix it. It will be cheaper than buying the kit to do it yourself and they'll do it right.
Cevan |
Thanks for the replies. Looking back on what I did, it's pretty obvious now that I shouldn't have done it. I do have 2 core motors, so I have a couple of backup cases just in case. I will look to have a machine shop put in a threaded insert.
Van |
Member ![]() ![]() Group: Members Posts: 199 Joined: 15-January 08 From: Hyde Park, NY Member No.: 8,571 ![]() |
Cevan |
They should thread in tight like that. The only time you tap them is when you are installing ARP head studs. How about getting ARP studs? (And tap the other holes.) That is an expensive option. $329 for just the studs. Yikes. I can't even find a machine shop to put in the threaded inserts. (IMG:style_emoticons/default/mad.gif) I think I'm going to use the case from one of my core motors. I've already got one down to a short block. |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
[EDIT] My bad - I was thinking exhaust studs. Disregard[/EDIT]
Step studs are cheap. There's room to retap if you get the right size. My local VW shop carried them. (IMG:http://www.034motorsport.com/oscthumbwm/w/400/h/421/q/95/f/jpg/fltr/wmi|phpThumb/watermarks/034watermark|C|20|0/hash/26709e0d5744acc2ca52913d9b509b73/src/images/StepStudM10toM8a.jpg) |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
You should have used a thread chaser, not a tap. The chase has much shallower roots and doesn't create this issue.
Now that it has occurred you can drill the case 2mm over size and install a time-sert. Thats your best bet for something thats fairly easy to do and inexpensive. |
Cevan |
You should have used a thread chaser, not a tap. The chase has much shallower roots and doesn't create this issue. Now that it has occurred you can drill the case 2mm over size and install a time-sert. Thats your best bet for something thats fairly easy to do and inexpensive. I hope others learn from my mistake. I contacted my local Time Sert dealer and the kit plus the correct size inserts is a little over $100. Do I need to have a machine shop drill and tap the holes in order to keep everything square or is this something I can hand drill and tap? |
brp986s |
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 ![]() |
Definitely have a shop do it, and a good one at that. I had a case messed up by some hack where the studs ended up pointing every which way like some bucktoothed hillbilly. The studs need to be square or it will confound your torque values. It would be a bummer to blow $100 on inserts then toss the case.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
You should have used a thread chaser, not a tap. The chase has much shallower roots and doesn't create this issue. Now that it has occurred you can drill the case 2mm over size and install a time-sert. Thats your best bet for something thats fairly easy to do and inexpensive. I hope others learn from my mistake. I contacted my local Time Sert dealer and the kit plus the correct size inserts is a little over $100. Do I need to have a machine shop drill and tap the holes in order to keep everything square or is this something I can hand drill and tap? Do you have a drill press? Rich |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Just make sure your table is square to the spindle otherwise big problems. |
Katmanken |
Most drill presses aren't an option....
That is, the table is usually way too small to support the case, and the depth from the drill axis to the drill press support shaft may prevent the case from fitting. An end mill, there's a real tool for the job. |
r_towle |
A drill press with a large top bolted in place will work quite fine considering he will be drilling simple bottomed out holes that are 5/8 inches deep.
While you might be tempted to spend all your money at a machine shop, have some confidence and drill the two holes, put in the time certs and call it a day. Rich |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Thanks for posting this mistake. I have done similar and didnt know it. Now I get why I got the results that I did. I dont know everything and still find enlightenment in many posts around here (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 4th July 2025 - 02:57 AM |
