michaelmoo |
Member ![]() ![]() Group: Members Posts: 312 Joined: 21-May 04 From: Kennesaw, GA Member No.: 2,092 ![]() |
Is the auxiliary air valve powered by a keyed 12v source? I know it is pin 12 (on the 12 pin connector) on the relay board, but is that a keyed 12 volt source.
Attached thumbnail(s) ![]() |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
It is powered by the fuel pump relay.
michaelmoo |
So since it is powered by the fuel pump relay then it is a 12v keyed source. Correct?
blitZ |
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States ![]() |
ejm |
No it is powered when the fuel pump relay closes which is controlled by the FI system. There is a terminal on the relay board (T-1) that can be grounded that will close the fuel pump relay when the key is on but this is not the same as a "keyed 12V source"
michaelmoo |
Thanks ejm. I see it now.
Thanks! |
Lo-Fi Version | Time is now: 15th June 2024 - 01:38 PM |
