Pulling the heads for the first time. |
KaptKaos |
Feb 14 2010, 08:28 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I am pulling the heads on my 1911. I want to make sure I do this correctly, as I will be putting it back together.
I have removed the fan shroud and the tin. I have removed the rocker arms, push rods and the springs that hold the tubes in place. Push rod tubes and lifters are still in place. Can I leave the push rod tubes in place and pull them with the head? Or do I pull them first? Is there any special order to remove the nuts that hold on the head? I've already hit them with penetrant. Let me know. TIA. |
tornik550 |
Feb 14 2010, 08:37 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
It doesn't matter if you remove the push rod tubes before or after removing the heads. I personally think its easier if you remove them after.
It also doesn't matter which order you remove the nuts. |
tornik550 |
Feb 14 2010, 08:38 PM
Lo-Fi Version | Time is now: 15th June 2024 - 06:47 PM |
