Zundfolge |
Senior Member ![]() ![]() ![]() Group: Members Posts: 847 Joined: 12-August 07 From: Colorado Springs Member No.: 7,994 Region Association: Rocky Mountains ![]() |
I have a Dino steering wheel with adapter.
Don't know what model it is, all it says is "Dino" on the front and "Made in Italy" on the back. It fit fine on my 914 but even though it has the tab thing for shutting off the turn signal it never turned off the turn signal (and there's a bit of a gab between the wheel and the steering column ... I assume it needs some sort of shroud or I was just doing it wrong, I'm not sure). The plastic tab thing on the back side has a VW logo on it (you can't see it well on the pic). The center cap is a horn button. It measures 14-3/4" from outside edge to outside edge. Its a nice wheel, I just prefer the stock one. It doesn't show up in the pic but there is a little scratch about half an inch long on the top left spoke. Not sure what this is worth so let me know if I'm way off base but I figured $75 sounded right (plus shipping). (IMG:http://www.macvanpublishing.com/mike/forsale/Dino_Front.jpg) (IMG:http://www.macvanpublishing.com/mike/forsale/Dino_Back.jpg) |
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
I am definitely interested. I will pm you when I return from the SCCA meeting. Donald |
Zundfolge |
Include your zip code when PMing and I can figure out what shipping would be.
Zundfolge |
Still available!
Zundfolge |
Apparently there's a difference between early and late steering columns.
This wheel fit fine in my 1970. |
nomore9one4 |
Member of the Eastcoast Thread Killers Club ![]() ![]() ![]() ![]() Group: Members Posts: 2,666 Joined: 26-December 02 From: Pittsburgh,Pa.15237 Member No.: 14 Region Association: None ![]() |
I will give you $85 shipped to Pittsburgh.Pa.15237 Deal? (IMG:style_emoticons/default/smile.gif)
Zundfolge |
I've got a couple of other interested parties.
So faux916, that would put you 3rd in line. I'll let you know what happens. (IMG:style_emoticons/default/smile.gif) |
nomore9one4 |
I've got a couple of other interested parties. So faux916, that would put you 3rd in line. I'll let you know what happens. (IMG:style_emoticons/default/smile.gif) No problem! Thanks. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 13th June 2024 - 06:42 AM |
