Clutch slips under load, clean or replace?, need help checking situation in my photos |
Chris Pincetich |
Feb 27 2010, 09:23 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Pics are worth a thousand words, so take a look below at what I am trying to deal with.
My clutch slips a bit under load, and I see some blue oil in the bellhousing. Not a lot, but other clutch photos on here show a dry, dusty bellhousing. I would appreciate advice on the wear to my clutch, PP, flywheel. I am not sure if I need to buy anything or just clean it all and go...and replace some transaxle seal(s). More on that later....diner is almost ready (IMG:style_emoticons/default/beerchug.gif) The disk and PP are only 2 years old, less than 5 k miles and 6-8 AX races. Attached image(s) |
SirAndy |
Feb 27 2010, 10:30 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Cleaning won't help, the surface looks glazed.
Fix the leak(s), have the flywheel and pressure plate resurfaced and get a new clutch disk. Don't forget to check the pivot ball for leaks as well ... (IMG:style_emoticons/default/shades.gif) Andy |
McMark |
Feb 27 2010, 11:39 PM
I can help you replace the seals if you wanna lug the transmission up to Sonoma. I've got all the tools that make it easy.
Chris Pincetich |
Mar 1 2010, 02:55 PM
Hey Limo Team,
Thanks for the advice. McMark - you have a voicemail, reply here or call me. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 07:10 PM |
