Floorpan cross tube thingies, Best way to cut them out? |
campbellcj |
Mar 28 2004, 10:26 PM
I can't Re Member Group: Members Posts: 4,549 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I finally made some more progress on the car this weekend -- finished the engine compartment side of the fuel line and Weber fuel bar replacement, redid the rear f/g bumper mountings (dzus) and pulled the seat to begin a bunch of interior stuff.
To mount my new seats, I will need to channel or completely remove the box section that goes across the floor pans (i.e. approx. under your knees). The seats will be on alloy sidemounts that are bolted directly to the floor, which I'll reinforce a bit. Question is, should I hunt down a plasma cutter or cutting torch (i.e. pay a shop) or can this be done decently with what I've got, i.e. just about anything else (cutoffs, grinders, drills, etc)??? (IMG:style_emoticons/default/confused24.gif) I don't want to butcher the floors as they're fairly clean and I don't have a welder, either. (IMG:style_emoticons/default/unsure.gif) Thanks again 914 gurus! (IMG:style_emoticons/default/pray.gif) |
SirAndy |
Mar 28 2004, 10:41 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
plasma cutter is the easiest. just remember to angle it up a little bit, otherwise you'll torch through the floorpan. it also helps to have the tar removed prior (IMG:style_emoticons/default/wink.gif)
i supose a cutoffwhell would do the job too. i'm not sure, is the crossbar spot-welded? if so, you could try to drill them out and remove it as a whole. ADDED: if you go with the plasma cutter cut about 5mm above the floorpan to avoid melting the floor. Andy |
Brad Roberts |
Mar 28 2004, 10:46 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Chris,
Just notch them and fold them forward for your seat. Cutting it without a plasma or a cutoff wheel would be a ton of friggin work. You could drill out the spot welds... but you stand a chance of drilling through the floorpans..plus you would be there all week trying to drill them out while hanging from the cage. B |
campbellcj |
Mar 28 2004, 11:10 PM
Thanks guys...I was starting to think that just notching them would be the "way to go". They do appear to be spot welded but a LOT of spots! Plus I figure the remaining metal will add some degree of stiffness to the floors.
I'll try notching, folding forward and then cutting/grinding off the excess sheet metal. |
Brad Roberts |
Mar 28 2004, 11:14 PM
If you dont fold them forward the seat bottom will sit on it before your holes line up for the bracket.
OH! OH! OH! DONT line the seat up straight with the steering wheel. The left seat bracket needs to be about 1/4 forward of the right seat bracket. If you dont... the high side bolster of you seat will have your right knee hyper extended trying to bend towards the gas pedal...so angle the seat a *little* towards the gas pedal. If you notice.. the steering wheel is not lined up straight with driver.. so the seat position works out perfect even at a slight angle. B |
campbellcj |
Mar 28 2004, 11:40 PM
I was actually looking at the angles (hanging upside down from the cage half the time) for quite a while this afternoon.
Is it fair to say that I want to stick with the lines of the stock seat mounts? They are clearly not "centered" with the steering wheel but they obviously work quite well in the real world. Oh yeah, if nobody guessed yet, my "old school" Koenig race seats were on the stock rails. Time to get rid of that less-than-solid mounting setup, and the 45lb seats... |
Brad Roberts |
Mar 29 2004, 12:00 AM
They work well because the stock seat has no side bolster to speak of. Just be careful. I know I cannot mount Momo's or Sparco's in line with the stock holes..and forget a Kirkey or something similar.
B |
Jeroen |
Mar 29 2004, 04:27 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Slightly related...
What's the best way to reinforce the floor without gaining too much height? Anyone got any pics of the floor before the seats/side brackets are mounted? cheers, Jeroen |
machina |
Mar 29 2004, 06:57 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
we made a pretty heavy duty bracket welded to the floor, at least .125" steel, maybe more. It is only about .25" off the floor at the rear and about 1" at the front to angle the seat back.
Also the frame is drilled out where the stock lap belt mounts are and the anti sub mount is welded to it at the center. The frame needs to be extremely strong. It has to withstand a huge amount of force if and when you go off hard. dr Attached thumbnail(s) |
Rusty |
Mar 29 2004, 08:52 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,942 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Got pics of the old seats? Whatcha gonna do with them?
-Rusty (IMG:style_emoticons/default/smoke.gif) |
machina |
Mar 29 2004, 09:12 AM
they are sitting in my office.
someone on the board wants them but they are too expensive to ship. any ideas? dr |
seanery |
Mar 29 2004, 09:22 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
ship 'em Greyhound.
JWest |
Mar 29 2004, 09:25 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
I concur - Greyhound.
jonwatts |
Mar 29 2004, 09:27 AM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
Yeah, that way they can charge passengers to sit in them (IMG:style_emoticons/default/laugh.gif)
But seriously, they would be perfect for this. Cheap and reliable. |
Jeroen |
Mar 29 2004, 03:41 PM
Thanks for posting the pics!
cheers, Jeroen |
Lo-Fi Version | Time is now: 9th June 2024 - 02:08 PM |
